Drainage Problem In Backyard - Planting Cedar Will Help? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 01:38 PM   #1
Rewards Points: 16
Drainage problem in backyard - Planting Cedar will help?
I think this drainage question has been asked many times, but my friend suggested me an interesting solution, I want to get some opinions.
Problem: Basically whenever it rains, there is a pond near the edge of the fence at the back of my backyard, I think all the water from my own house and my neighbor's house runs to the lowest point which happens to be my yard.
Proper Solution: I did some research on the Internet, and I KNOW that by putting weeping tile, French drain, and probably a dry well will probably solve this problem. However, the scale of construction is too huge for me to handle. Also, I know that if I put soil and raise the grade, I will got into risk by getting sued by neighbors.
Interesting Solution: Now, my friend suggested me to plant a series of Cedar in the problem area along the fence on the back of my backyard. Will this solution work? Well Cedar be able to absorb all the water quick enough? Will too much water kill the plant? Any suggestions?
Thanks.
R.B.
riniboo is offline   Reply With Quote
Old 04-11-2010, 02:33 PM   #2
Remodeling Contractor
planting will not help. Bamboo will absorb enough water but is very invasive and the neighbors will really kill you for that solution.
Old 04-11-2010, 10:23 PM   #3
jlhaslip's Avatar
Rewards Points: 2,884
Cedars do suck up a fair bit of water, but it sounds like you would need a forest of them.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Tags
backyard , drainage , sweeping tile
Drainage problem - Rain Barrel? Leah Frances Landscaping & Lawn Care 4 01-30-2008 06:20 PM
balcony drainage problem darsunt Flooring 1 08-31-2007 12:46 PM
water drainage problem.... joshua5438 Landscaping & Lawn Care 1 06-20-2007 11:05 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
deck drainage problem darsunt Building & Construction 4 12-30-2006 12:45 PM
