Drainage And An Open Grass Area 30" Below My Backyard's Level - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 04:40 PM   #1
Question
Drainage and an open grass area 30" below my backyard's level
Hello
I'm planning a landscaping of my backyard and I want to put in an area of grass in the middle that is 2.5' below the rest of the yard. I really like the look, and I think it will add dimension to the current flat layout.
Here's a link to the rough design:
http://i.imgur.com/Wrilc.png
The grass area is about 21' wide by 33' deep, covering (I'm guessing) around 500 sq ft.
What are the rules for drainage here? How does that all work, and what methods would I employ to make sure that this area does not become a pool when we get a big storm?
FYI - I live in San Jose, CA, and we get (typically) a mean annual rainfall of 14.4 inches. Our biggest storm in recorded history gave us just a bit more than 2 inches in one day (1995 according to NWS).
In a worst case scenario, let's say I get 2 inches every day for three days. That's about 250 cu ft.
If I dig a hole that's 8' x 8' x 4' (256 cu ft) and fill it with drainage rocks, then put the lawn over that, will it be enough for drainage? If not, why? (I understand that the rocks take up space, but I'm hoping that the water can drain out over time)
Thanks,
-----------------S
spdorsey is offline   Reply With Quote
Old 09-12-2011, 05:21 PM   #2
DIY staff
Rewards Points: 7,174
Just thing out loud here-----A sump pump could handle that much water and you never freeze there--
Might be a solution at a reasonable cost---I'm no landscape guy but I think it would work.
Old 09-12-2011, 05:46 PM   #3
Question
Sump pump
How would one go about placing a pump under a lawn? I mean without having a big plastic or wood trapdoor in the grass?
Old 09-12-2011, 07:07 PM   #4
DIY staff
Lift up stairs---little pond--small wood landing at bottom of stairs---fake wind mill--(yuck)
I'll bet you can come up with a 2x2 cover somewhere.
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
Drainage, grass issue. Bcoleman6 Landscaping & Lawn Care 2 03-22-2008 11:53 AM
