Drainage Issues And Water In The Basement - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-14-2008, 10:40 AM   #1
Drainage issues and water in the basement
http://picasaweb.google.com/Jfatica/Drainage_problems
I have a good idea of what I plan to do to relieve this drainage issue, but I am curious as to what other ideas people may have.
I plan to run two french drains away from the house to the street, and possibly into a drywell. I need to even out the grade against the foundation between the window-wells. I'll probably remove those bricks around the trees to hopefully increase the flow of water away from the house.
Thoughts, ideas?
diskman is offline   Reply With Quote
Old 04-14-2008, 10:52 AM   #2
concretemasonry's Avatar
Rewards Points: 2,626
First, get some decent length downspout extensions. Right now you are just dumping the roof water next to the house.
When you say "french drains", what type do you mean.
Are you considering deep tile at the footing depth (inside or outside) or just some shallow interceptor-type parallel to the house and then running toward the street?
It looks like the frost was still in the ground when the pictures were taken or you have impermeable soil (clay like). If you have impermeable soil, you could easily fill a drywell unless it is very large.
How much slope do you have to the street/gutter?
concretemasonry is online now   Reply With Quote
Old 04-14-2008, 11:20 AM   #3
I was just planning on two drains perpendicular to the wall (parallel with the garage). I was planning on going down pretty deep (3 or 4 feet), the basement is only about 5.5 feet tall from the top of the window to the floor, and I'm not sure if a footer exists or not (house was built in 1906).
Was gonna use 3 or 4 inch pipe covered in cloth, then stone, then enough top soil on top to grow grass.
The slope from the house to the street is not much but there is a slight slope. Not sure if you can tell form the pics, but there are some low spots (almost like grooves) between the house and the street where the water pools.
That is the only downspout on that side of the house, but I was definitely planning to extend that as well.
The front side of the house (not pictured) has the gutters run underground to the street where they come out a little hole in the curb and drain to the sewer. Unfortunately, this side of the house does not have a curb on the street and no sewer close by.
Old 04-14-2008, 01:32 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Thoughts, ideas?
I would install a french drain, drywell, daylight drain and incorporate your downspout into the plan.
The french drain will be along the perimiter of the foundation, doesn't need to be too deep. extend that to a drywell next to street. The drywell should have an overflow at the lowest spot near the street. They make pop-up outlets for this. Also extend your downspouts to the drywell. Of course make sure your grade is sloped away from the house.
I have this with a just below grade french drain and a footer drain. In very heavy rains my drywell gets saturated and overflows but is away from the house and continues to flow away. I also have a waterproof membrane against the foundation. basement is bone dry.
Brik is offline   Reply With Quote
Old 04-19-2008, 09:53 PM   #5
I agree. The French drain will do wonders, assuming it's installed correctly.
Allison1888 is offline   Reply With Quote
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 07:38 AM
Drain Water Heat Recovery Devices - Thoughts? Educator Plumbing 21 04-12-2008 07:29 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 09:19 PM
Tankless hot water sporatic until........ Ronin33 HVAC 15 06-05-2007 03:12 AM
water heater issues Missydo Plumbing 17 04-05-2005 09:31 PM
