Drainage/Erosion NIGHTMARE!! Please Help! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-20-2009, 08:44 PM   #1
Jamer2168's Avatar
Drainage/Erosion NIGHTMARE!! Please help!
We have this beautiful home, on beautiful land, however, this year the nightmare began. The drainage water from melting snow compounded the problem that started with last summers flooding and terrential rains in central Iowa.
The run off has literally washed out the ground around the foundation. Water is now seeping into the basement from under the foundation as well as through the walls.
Is there any way to keep this from washing out in the future? I've decided maybe this home isn't worth keeping so am dreaming of most inexpensive way to hold temporarily? Is there really such a thing?
I uploaded some photos also to give everyone an idea of the extent of damage done as well as terrain of land surrounding the problem. Any suggestions are greatly appreciated!!! Thanks!!
Drainage/Erosion NIGHTMARE!! Please help!-home-erosion1.jpg   Drainage/Erosion NIGHTMARE!! Please help!-home-erosion2.jpg   Drainage/Erosion NIGHTMARE!! Please help!-home-erosion3.jpg   Drainage/Erosion NIGHTMARE!! Please help!-home-erosion4.jpg
Jamer2168 is offline   Reply With Quote
Old 03-20-2009, 10:21 PM   #2
Rewards Points: 1,088
There is usually no simple solution to drainage problems, but, it looks to me like you need to build a retaining wall to hold that dirt back at that corner of the house.
Behind the retaining wall should be plenty of gravel with corrugated piping in the bottom to channel the water away from the house.
handy man88 is offline   Reply With Quote
Old 03-21-2009, 12:26 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,710
Ayuh,... The Easiest,+ permanent Fix would take a couple of hours with a Bulldozer...
The swale above the house by the big tree needs to be slightly deepened,+ the house side raised slightly...
If that were continued out past the little green tree,...
The water would by-pass the house, All together...
Old 03-21-2009, 06:30 PM   #4
Jamer2168's Avatar
Please forgive my stupidity, but swale...is that the apparent dip between the big tree and the house? I'd never noticed that before. Getting a bulldozer in there maybe a problem due to sewage tiles are located on the front side of the house on that corner and maybe too heavy?
We have now been told by two landscapers and the neighbors that the house most likely should have never been built. The property is also an old strip mine. We're trying to stay away from the cost of a retaining wall but are coming to the conclusion that may be the only option.
Is there a way to do such a project with minimal expense? Are there certain materials anyone can suggest to keep the cost down?
Old 03-21-2009, 08:00 PM   #5
Don't know it all, yet!
Even though I'm from Georgia, the first time I heard of a swale, I thought someone had a worse accent/drawl than mine. Think "swell" with a drawl.
A swale is just basically a ditch for directing drainage. Note- basically. Just enough of a depression to pull the water and still shallow enough that you can still go over it with a mower, etc. You wouldn't really need a bulldozer. It would be nice, but a tractor with a grading blade could accomplish the job with less intrustion on the lawn.
Or, fill that washed area next to the foundation and while you're at it, add a slight berm (raised area, opposite of swale) out to that little cedar (?) and plant it with some shrubs. I understand that you are trying to do this on a budget.
This would be my choice mainly because:
Some plant material would be really useful there;
The bottom line is that you want the ground to slope away from the house and it doesn't matter to the water whether it goes into a swale or just downhill from the house with the elevated soil;
Roots from the plants would hold the soil and help prevent this in the future.
A nice groundcover would serve the purpose, or some shrubs underplanted with groundcover.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 03-21-2009, 08:28 PM   #6
You can buy retaining wall blocks & build the wall
You'd need to dig out & back fill with gravel & install a drain
And plastic too would redirect the water away
Its quite a bit of work
Old 03-21-2009, 11:05 PM   #7
To keep costs down for a retaining wall, use 6x6 PT lumber vice stone. If you do this, because of the height of your wall, it'll probably have to be tiered.
Old 03-21-2009, 11:06 PM   #8
BTW, it seems kind of comical how a lonely dwarf alberta spruce is somehow planted in the middle of this.
Old 03-21-2009, 11:53 PM   #9
Jamer2168's Avatar
Do I find a sense of satisfaction finding humor in my turmoil??!! HA!! You know, considering I have NO design/landscape backround nor ambition to acquire such, I guess I never thought much about the dumb tree nor the fact that it does look a little, um, forlorn. Oh well... Lessons learned from impulse buying at an auction...For REAL!! Love the house, but probably should have done a little homework before out bidding the competition that day... Hmmm...
Thanks to everyone who threw in some ideas...I will keep you posted...Also if anyone comes up with any other thoughts, please don't hesitate to throw your two cents in....I'd love to hear any ideas!!
Old 03-22-2009, 05:15 PM   #10
No satisfaction here from your predicament.
Know this though....sometimes, you have to laugh, otherwise, you'd cry, especially when it comes to home ownership.
Before, I've always wondered why people retire to Florida, Arizona, etc to a condo after living in a SFH with land all their life. I don't wonder so much anymore.
Old 03-23-2009, 05:20 PM   #11
Bondo's Avatar
Ayuh,... I'm no landscape designer by any means,... I think the only thing you need to look at is,..
Water flows Downhill...
You need a grading contractor to fix your lot drainage....
All your pictures after the 1st are of the Results, not the Problem...
Looking at the 1st picture,...
You need to drain the sidehill on the left, either around the back of the house, or more likely by swaling it to drain to preferably as far to the left of the picture as Possible...
It appears that that bit of swale now daylights, right behind the little tree...
While that's being done,...
Look at the upper part of the yard near the house,...
That grade drops to the house from right above the little tree as far as can be seen,...
That's a large area to drain, especially when 1/2 of the house roof also drains there...
That's what's causing the massive erosion at that corner of the foundation...
You need the land to fall away from the house for 15' or more, to a swale to carry the water around the house....
It could be done in a few hours with a dozer,+ the material that's on site,..
Or,..
You could put a small wingwall retaining wall coming off the left corner of the foundation, towards the photographer...
That would allow lesser drops in the grades,+ daylighting the swale as far to the left as possible...
The erosion will stop,+ you can grow grass in that corner, once you divert the flows..
Old 03-23-2009, 05:32 PM   #12
Maybe I missed something.
Old 03-24-2009, 02:25 AM   #13
Looking at the pictures, the problem might be more complex than just a "swale" fix. You have a fair amount of sloping terrain which "dead-ends" towards the home. You would be surprised as to the volume of water that is heading towards your home and that foundational wall.
I am also VERY TROUBLED by the last picture. When you look closely, you can see that the bricks on one side DO NOT match the brick line on the adjoining wall. This is SERIOUSLY BAD. The wall appears to have already dropped/shifted away from its original spot. In other words, the wall has already failed, and it can and only will get worse from here.
Did you have a home inspection done before you bought the home?
If so, the inspector should have spotted this on his/her report.
Many times people don't realize that not only is the above ground (what is visible) water headed towards the home but you can have underground "streams" that travel towards the home. These "streams" are usually only active in rains but have been noted to even flow days or even weeks after rains have stopped.
I would call an expert and have them evaluate the area:
1 - Do soil samples (what type of soil do you have, how saturated is it, what is the percolation/drain qualities)
2 - check for underwater streams and flow (they use high-end equipment and sensors that can show if and how much water is flowing underneath the ground)
3- excavate and head off the flow of water using French Drains and or other methods to divert the water AWAY from the home
4- inspect the wall for how much damage it has. It may already be compromised to the point that it might need to be repaired.
Once again, judging from the pictures, there is a large amount of sloped area. I would state with 95% confidence that you have an underground water flow source/stream that is flowing into the home.
This issue MUST BE ADDRESSED ASAP. Eventually the wall that is leaking can and will be compromised and can actually fail. Water is a tremendous force. It can & does move mountains. That wall is no match, they are not designed to hold back heavy flows of water, it will fail and collapse.
I've seen it happen first hand. The wall collapsed INTO the basement. You DO NOT want to wait until that happens.
JackOfAllTrades is offline   Reply With Quote
Old 03-24-2009, 11:05 AM   #14
RippySkippy's Avatar
I don't think I would get too worked up over that...it's just the form design that doesn't line up..I really doubt there's anything structural with the offset...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-24-2009, 11:29 AM   #15
Concrete & Masonry
Rewards Points: 636
I agree 100%. That corner hasn't & wont move anytime soon. Note the tar damproofing still lines up. Ask around & find the names of a few excavators to look at it for you. You have plenty of room to raise the grade at the house to divert water. They could probably also get a french drain in below ground level at the exposure & set some boulders for retention on the left corner of the foundation to help with erosion. And they could probably do all the work for less than you would pay a real estate agent in commission. Good Luck!
jomama45 is offline   Reply With Quote
subfloor nightmare baltimore Flooring 10 04-17-2009 01:46 PM
Waterheater nightmare + too much pressure in house lukin Plumbing 1 11-15-2008 02:15 AM
Wood staining nightmare clamityjane Interior Decorating 8 08-22-2007 09:16 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General DIY Discussions 18 08-10-2007 10:04 AM
1/2 bath remodel nightmare Jeekinz Plumbing 3 03-30-2007 11:25 AM
