Drainage Behind Garage - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 02:38 PM   #1
drainage behind garage
I had water issues behind my garage because grade was up 2 feet. I dug it out put foundation sealer on the block and have a 4 pipe going around the corner. So anything else i should do before i close it up?
kevin07 is offline   Reply With Quote
Old 09-05-2013, 03:14 PM   #2
Rewards Points: 13,456
Where's it going to drain to?
Someone really messed up when framing that garage.
The bottom plate was supposed to be installed so the sheathing could be run past the foundation.
The way it is now waters going to be running in under the wall and rotting out the sheathing.
Need some flashing at the bottom of the wall up behind the wall and out over the foundation.
Old 09-05-2013, 03:50 PM   #3
The block your seeing is a second row not part of the foundation i have a feel they just put it in to stop water it was parged the seething should be fine
Old 09-06-2013, 06:07 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,042
Ayuh,... The holes in the pipe are supposed to point down, not up,...
Bondo is online now   Reply With Quote
Old 09-06-2013, 07:02 PM   #5
Parged, second wall or not, no amount of caulking is going to keep the water built like that.
Parging is not water proofing, it's just for looks.
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 01:08 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
