Drain Line Under Sidewalk - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 10:55 PM   #1
Rewards Points: 260
Drain line under sidewalk
I need to run a 4" drain pipe under a sidewalk. Is there an easy way to do this?
bluefitness is offline   Reply With Quote
Old 08-18-2009, 11:37 PM   #2
Rewards Points: 150
cut a 4" piece of the sidewalk out and start digging? Or pull up the whole sidewalk pad?
johnnyboy is offline   Reply With Quote
Old 08-23-2009, 09:41 AM   #3
TooledUp
I do not think so. I think you can dig from both sides and then eventually under the walk until you have enough room to slide your pipe in there.
TooledUp is offline   Reply With Quote
Old 08-30-2009, 12:48 AM   #4
Rewards Points: 1,016
With a smaller pipe you could use the pipe as a water drill, I did this once with 2" and went under a street - was a bear to do and took a jack hammer as modivation to the pipe. The city would not allow the street to be be dugup or even closed. I don't think you could do the water drill thing with 4" pipe.
Digging under half way from either side of the sidewalk would be my suggestion. Not easy I know, but should not be too bad.
Advice needed for draintile under sidewalk dgbehrends Landscaping & Lawn Care 5 11-17-2009 01:03 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Clogged Drain line Ruski Remodeling 2 06-24-2009 07:29 AM
Cutting Concrete for drain line Piney Building & Construction 2 12-01-2006 08:42 PM
