-   -   Drain line under sidewalk (http://www.diychatroom.com/f16/drain-line-under-sidewalk-51214/)
bluefitness 08-18-2009 09:55 PM
I need to run a 4" drain pipe under a sidewalk. Is there an easy way to do this?
johnnyboy 08-18-2009 10:37 PM
cut a 4" piece of the sidewalk out and start digging? Or pull up the whole sidewalk pad?
TooledUp 08-23-2009 08:41 AM
I do not think so. I think you can dig from both sides and then eventually under the walk until you have enough room to slide your pipe in there.
vsheetz 08-29-2009 11:48 PM
With a smaller pipe you could use the pipe as a water drill, I did this once with 2" and went under a street - was a bear to do and took a jack hammer as modivation to the pipe. The city would not allow the street to be be dugup or even closed. I don't think you could do the water drill thing with 4" pipe.
Digging under half way from either side of the sidewalk would be my suggestion. Not easy I know, but should not be too bad.
