Down Pipe Run Off/ Channel Grate Drain Install - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 08:26 AM   #1
down pipe run off/ channel grate drain install
down pipe run off/ channel grate drain install-drainage-plan-words.jpg
Hello, I need to redo and install some pipe work around the side of my house as water tends to build up and has no where to go,
I have drawn a diagram of what I intend to do,
so basically it will be a new floor grain, with one downpipe connecting to it, then both connecting to an L shaped grate drain, which connects back into the 90mm pipe, the runs down picking up 2 other down pipes and another bit of grate drain from the shed.
my question is,
will this 90mm (3.54inches) pipe be large enough to handle 3 downpipes and grate drain in between?
I am sure 90mm is the standard here in aus for most drainage, and many connections (corner pieces, T shape etc) are available for it but not so many for larger piping.
Please let me know what you guys think,
thanks alot!
breakerboy2000 is offline   Reply With Quote
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 01:28 AM
drain pipe slips off tail pipe tomad51 Plumbing 4 07-04-2011 03:06 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
