Dowel Fence Install - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 10:29 AM   #1
Rewards Points: 91
Dowel fence install
All,
I am ordering fence panels and the manufacturer thinks that "doweling" the fence in is a better method. I spent a little time on Google with little results. Has anybody ever done this? If so do you have pics?
tjfslaughter is offline   Reply With Quote
Old 05-31-2013, 04:27 PM   #2
Rewards Points: 91
It depends on what you're trying to accomplish. When I think of a dowel fence, I think of what you see on a typical ranch. If you want it purely to keep your cattle in, or for aesthetics, then sure, go with dowels. If you want any sort of privacy or to keep kids or dogs in (or out), then a normal privacy fence could be what you're looking for.
At the end of the day, totally up to you and your needs and preferences.
NegativeTen is offline   Reply With Quote
Old 05-31-2013, 05:04 PM   #3
Rewards Points: 13,750
I've never once heard of doweling a fence.
Got a web site or picture of this fencing.
No way is a dowel going to hold a fence up. One wind and it's down.
Old 05-31-2013, 06:29 PM   #4
Rewards Points: 3,630
Originally Posted by tjfslaughter View Post
All,
This is a dowled fence.
http://www.parmapostandpole.com/dowe...-installations
Canarywood1 is online now   Reply With Quote
Old 05-31-2013, 06:47 PM   #5
All,
Just gave your question some more thought,and you said fence panels,which means the manufacturer's talking about the cross members of your fence being dowled in as opposed to being fastened to the posts with say nails,more i think about it the better it sounds.
Old 06-01-2013, 02:30 AM   #6
Too Short? Cut it Again!
Sold tons of this type of fencing in lodgepole pine form. At least the base of the posts came treated. Lodgepole is surprising strong even though worthless if you slice it into panels.
It is a little tricky to set your post since you should fit the rails at the same time. Ours came fairly precision drilled and "doweled" I guess is a term that works for the ends.
We recommended dry setting the posts with something like Sakrete or just packing them with gravel and fill dirt. Some put a nail in through the post and rail to hold it in place but I saw no reason for it. As I said the challenge was staying level and plumb setting and fitting rails and posts at the same time.
I framing level and some nice string line and a string level are in your future. We also suggested digging or drilling the post holes a little larger than with dimensional timber so you could move the posts around if needed.
Now then, if this is not the fence system you are talking about, I have seen nice fences with few fasteners where the system was rail and tenon and the tenons slipped into the posts. Then dowels went through them. I worried how they would hold up outside but the Japanese no fastener houses have been standing for hundreds of years. Boats were built this way too at times.
I think if you tried this, I would be inclined to use a piece of stainless, nylon or a carriage bolt system and some wood plugs to fill the recessed holes. I have used and carriage bolts on benches, trellises and things and hidden the fastener ends this way.
Old 06-01-2013, 06:22 AM   #7
Rewards Points: 91
The dowel and post fence is not what I am looking at.
I am buying tongue and groove cedar fencing. It was explained to me that in New England most installers take a dowel rod and drill into the 8 foot post and slide the end of the fence into the dowels. The fence is has 3 horizontal post on each face. This means there is 6 dowel pins holding it in. Once pinned you install a set screw out of site.
When I use search engines I come up with the same images and fences you guys are talking about.
Old 06-01-2013, 07:29 AM   #8
Rewards Points: 236
show some pics of the type of fence you are talking about.
Fix'n it is offline   Reply With Quote
Old 06-01-2013, 07:30 AM   #9
Rewards Points: 236
http://www.sentryfence.net/0604121259a.jpg
Old 06-01-2013, 01:00 PM   #10
I've been doing woodworking as a hobby for 50 years and i can't even visualize what you explain,if you come up with a pic please post it,you have my attention.
Old 06-01-2013, 03:15 PM   #11
Rewards Points: 91
From the description it sounds like it's done for added stability over typical tongue-and-groove style panels. Though, to me it sounds like someone's just trying to up-sell you. Maybe in the north east a stronger joint for modular fences helps out because of strong winds? I dunno..
Old 06-01-2013, 04:14 PM   #12
Rewards Points: 91
Originally Posted by Fix'n it View Post
Something like that but imagine butting the end of the fence into the centerline of the post. Where the 2x3"a (horizontal) butt up to the post it is secured with. 4 inch or so dowel rod.
Old 06-01-2013, 04:43 PM   #13
It's the tongue and groove part that stumps me.
Old 06-01-2013, 05:04 PM   #14
Rewards Points: 91
The fence is t&g cedar it is not that relevant to the mounting to the post
Old 06-01-2013, 06:12 PM   #15
Thats what over thinking gets you,thanks for clearing up.
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 1 10-10-2013 12:33 AM
Wood fence is warping skittles1984 Carpentry 2 02-20-2011 11:27 PM
Install Biesemeyer fence on craftsman table saw ronbrunet Carpentry 1 08-02-2010 06:49 PM
Building a fence on top of pavement mwalsh Landscaping & Lawn Care 6 04-20-2009 04:16 PM
Fence Bid - A Rip-Off ??? kenziekiss Building & Construction 7 12-31-2006 07:12 PM
