Do I Need A Backflow Valve For Hose-Sprinkler? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-29-2009, 01:57 AM   #1
jbk
Rewards Points: 12
Question
Do I Need a Backflow Valve for Hose-Sprinkler?
We're re-landscaping a 40' x 40' backyard in San Diego that was totally neglected by the previous owner. We'd like to put in a small (20' x 30') lawn area for our kids, a play area with a swing and a sandbox, and two rows of vegetable garden, and plant shrubs and ground cover for the remaining areas. We can't afford an in-ground sprinkler system, so I was going to just attach one of these faucet manifolds ...
... to our backyard exterior faucet, and make an above-ground sprinkler system with 3 different zones. Each of the 3 zones would be fed by a garden hose with a battery-operated timer. One of the 3 would be a sprinkler for the lawn. A second would be for the vegetable garden, and the third for a drip hose for the shrubs and ground cover. The 4th valve would be for a garden hose for manual hose use.
My question is, do I need to attach a back-flow preventer valve in my set-up? If so, can I attach one just at the top of the manifold? Or do I need one for each of the 3 manifold outlet valves connected to a sprinker or drip hose? Is there one you recommend?
Also, do you see any problems with what I'm planning to do?
Thanks.
jbk is offline   Reply With Quote
Old 09-29-2009, 03:25 AM   #2
Kap
Mowing my life away.
Considering you can get one for under ten bucks, I would use one.
http://www.mrdrip.com/backflowpreventers.htm
Kap is offline   Reply With Quote
Old 09-29-2009, 02:21 PM   #3
Too Short? Cut it Again!
Do consider installing a drip system for everything but the lawn. With a drip system you will be watering in outputs of gallons per hour (GPH) and not gallons per minute (GPM) and the water will only be discharged where you want it. You will save enough in short order to pay for it.
Old 09-29-2009, 06:20 PM   #4
Don't know it all, yet!
If you are using this strictly for an irrigation system, there is really no need to have a backflow preventer. Their purpose is to prevent anything from siphoning back into the water system in the event something like a water line was broken somewhere along the system, creating a vacuum of sorts from your house into the local water supply. So, if you were using a hose to apply fertilizers and/or herbicides you might want to consider having one.
First, I would check with my local water authority. Most places nowadays require a backflow preventer at the meter (on your side). So the question here may be moot.
If you do decide to install one at the faucet, just one at the faucet going into the manifold will suffice and will protect all connections downstream. But I can agree with Kap, if in doubt spend the ten bucks.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Tags
backflow valve
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Adding Sprinkler Valve to Existing zone tilphan Landscaping & Lawn Care 3 03-29-2009 12:35 PM
Sprinkler System - Installing Valve Box tazmajazz Plumbing 3 01-06-2009 09:14 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
sprinkler valve leaks deck hand Landscaping & Lawn Care 3 06-20-2008 08:36 PM
