Ditch From Hell, Need Help On How To Fix My Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-03-2009, 03:53 PM   #1
ditch from hell, need help on how to fix my problem
Two months ago I decided to reconfigure my ditch. Yesterday we received about 3" of rain in 1.5 hours and this morning, I noticed the ground sinking pretty bad where I had backfilled the ditch. What can I do to fix the problem? I used river sand as backfill, and it was compacted and flooded before planting the sod. The sod had been growing for about 4 weeks now. I used an earthen fabric that goes along the bottom of the ditch and wraps up just past the seam of the 2x8 and 2x10.
jonlorio is offline   Reply With Quote
Old 07-03-2009, 07:11 PM   #2
I think I am going to dig up 18-24" of soil behind the lumber, and re-fill with 57 limestone, then fabric, then sand/soil. Since the height of the walls are only 18", I don't think I need install the 4" perf. drain pipes, do you?
Old 07-06-2009, 05:54 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,.... I'd have used Dirt, not sand to fill,.... Dirt will shed water across it... sand allows it to soak in...
Bondo is online now   Reply With Quote
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 03:57 PM
Landscape drainage problem Miller-man Landscaping & Lawn Care 13 07-03-2008 12:06 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
