Dismounting Railing Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-29-2008, 08:04 AM   #1
dismounting railing problem
Hi,
I am dismounting the railing on my porch (pic 1) and don't know how. There are four places (marked in pic 1 as A, B, C, D) attached to concrete or bricks. I unscrewed all screws at point A and B in pic 1. I see only four screws at point C (pic2) and D (pic3) attaching to the brick post. But the space is too tight and my tools cannot reach it. Due to the restrictions of this site the pictures are cery small and hope you can get an idea.
I hope you guys can enlighten me on this one.
Thank you very much in advance.
Dawson
toronto1234ca is offline   Reply With Quote
Old 06-29-2008, 09:08 AM   #2
are you trying to save it to reuse
clasact is offline   Reply With Quote
Old 06-29-2008, 11:21 AM   #3
yes. I will reuse it.
Old 06-29-2008, 11:47 AM   #4
What I am going to do is stone tiling the porch and the steps and then replace the railing.
Old 06-29-2008, 12:44 PM   #5
OK well in that case they do make Allen type wrenches in a Philip's head that will let you get down in to it.I would soak them in penetrating oil first though
Last edited by clasact; 06-29-2008 at 02:59 PM. Reason: I cant spell worth a dang and forgot to use spell check
Old 06-29-2008, 01:47 PM   #6
ok well in that case they do make allen type wrenches in a philips head that will let you get down in to it.I would soak them in penitratibg oil first though
thanks for the tip. I will look at the allen type wrenches and use WD-40.
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 07:16 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 11:19 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
