Dischargw For Sump Pump - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-01-2009, 12:24 PM   #1
dischargw for sump pump
I'm installing a sump pump. Trying to decide if I should install a landscape outlet with an ice guard as recomended by basement systems or go with a drywell. It would seem discharging the water above ground may be an issue in the winter.
sglowa@cox.net is offline   Reply With Quote
Old 02-01-2009, 01:23 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Ayuh,..
I guess it will depend on the lay of your land, the size you have to work with,+ how complicated, ei; Expensive you want to get...
A thought on the Drywell Idea,...
Make sure it's far enough away, so you're not pumping the water in a circle....
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 10:42 PM
