dischargw for sump pump
1K views 1 reply 2 participants last post by  Bondo
#1 · (Edited)
I'm installing a sump pump. Trying to decide if I should install a landscape outlet with an ice guard as recomended by basement systems or go with a drywell. It would seem discharging the water above ground may be an issue in the winter.
Ayuh,..
I guess it will depend on the lay of your land, the size you have to work with,+ how complicated, ei; Expensive you want to get...
A thought on the Drywell Idea,...
Make sure it's far enough away, so you're not pumping the water in a circle....
