Dirt At House Is Above Lowest Brick Courses - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 01:01 AM   #1
Dirt at house is above lowest brick courses
In front of the house the top of foundation is about 8 inches above grade. But on the side, about 3 feet back from the from the front, the foundation steps down considerably. At least three courses of brick are covered with dirt when the dirt is level with the "shared" sidewalk 10 feet away.
it is a severe design flaw. the brick is chicago common and does not last long when wet.
I think my only option is to cover the bottom few courses of brick to protect them from the moisture. can anyone reccomend a good product to seal them, Should I jsut use the back tar spray used on concrete foundations?
Mikeee
pmracing is offline   Reply With Quote
Old 03-26-2009, 07:09 PM   #2
Duron makes a very good silicone sealer that will last 4-5 years. Not cheap but works well. You can use the black waterproofing but you reaaly need to pay attention to what you're doing or it'll peel off.
Dugger52 is offline   Reply With Quote
Old 03-26-2009, 07:20 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Definitely a bad construction detail - definitely does not agree with any code or common sense and could be a bad design if the landscaper actually followed the plans. If he did not follow the plans, it is the landscaper's problem.
Coating are just a temporary patch at best if the surface is prepared properly. If it is applied properly, it might last the "guaranteed length of time.
Dick
concretemasonry is online now   Reply With Quote
Old 03-26-2009, 08:20 PM   #4
Dick
I don't know what else to do, besides move. the only way to solve it would be to lower the side sidewalk. But then it would be a foot lower than the alley and would be a drainage problem there. but only in the yard, not in our basement...
Mikeeee
Old 03-26-2009, 09:13 PM   #5
If you had a masonry wall behind the brick, that would make a difference. Then you would not have to deal with the possibility od moisture damage to the main bearing wall.
Wood below a backfill has a limited life.
Old 03-26-2009, 09:48 PM   #6
it is a solid brick wall about 2 feet above the concrete foundation. then it changes to brick exterior with a concrete block interior.
Maybe that is why they did solid brick for the first two feet. It looked better?
Mikeeee
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Protecting siding base in dirt Bambu Building & Construction 11 08-11-2008 10:19 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 10:09 AM
