Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-26-2009, 02:02 AM   #1
Default Depth of the flower garden next to the concrete wall ?
I have 2.5 ft and 25 ft rectange flower garder next to my house concrete wall. Recently some one told me that the dirt in the flower garden should be below the level of carpet. This concrete wall is protecting 2 bed rooms.
Today I started digging the dirt until I found the division of the wall and the concrete..
Is this right ?
Is the dirt has to be below the floor level/carpet level ? If yes, why is that so ?
cprao is offline   Reply With Quote
Old 10-26-2009, 10:16 AM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
There should be a min of 6" between the wood walls on the house & any dirt
As long as a concrete wall is sealed properly it will be OK
Concrete wall or concrete block ?
Any pic ?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 10-26-2009, 11:06 AM   #3
Any pic ?
Thank you Dave. I don't know whether it is a concrete wall or a block. I recenlty purchased the house and also layman in understanding these terms.
I lost my my camera connector to PC to upload photos.. I am shopping for a new one. Once I have that I can upload photos to explain what I am really asking here..
Old 10-26-2009, 11:13 AM   #4
Obvious perhaps but make sure whatever the height of the garden that it is graded and drained away from the house.
sdsester is offline   Reply With Quote
Old 10-26-2009, 11:30 AM   #5
Thank you. I didn't think about this. Does that mean, when I dig and level the flower garden, I need to make sure the slope is on the other side of the wall/house so that the water flows away from the house.
Old 10-26-2009, 11:34 AM   #6
Scuba_Dave's Avatar
Yes - the dirt should be higher near the house
That way water will flow away from the house
Did you put the flower garden in, or already there?
Old 10-26-2009, 11:37 AM   #7
The flower box is alreay in. I was just making sure whatever is there they are in good shape..
Old 10-26-2009, 12:40 PM   #8
Scuba_Dave's Avatar
With 2.5' width you really shouldn't get a lot of water in the garden
Unless you don't have gutters & roof run-off is going into the garden
Or if a gutter is dumping water right into this garden
Old 10-26-2009, 07:32 PM   #9
I will post the picture in a couple of days so that it makes sense what I am talking about..
Old 10-27-2009, 07:20 PM   #10
Old fart still learning!
I presume that this is not a typo for carport. Notwithstanding termite considerations, I have never heard of this theory. For termite protection no soil should be within 6 inches of any of the wood framing, as already pointed out. Same for the slope that was already noted.
Going way out on a limb, maybe someone intended that advice in regards to interior flooding in the case of heavy rains. Do you know if your house is built on a concrete slab or is the flooring traditional lumber?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-27-2009, 08:41 PM   #11
No. It is not a typo. I am not sure whether the house is built on concrete slab or lumber. I believe it is on Concrete.
Old 10-28-2009, 07:14 PM   #12
My reason for asking about the slab or lumber is that with lumber your floor is the distance of the joists' width above the grade. With a slab, your floor is just about ground level, give or take. So if that is the case, and if there is not a very good joint seal between the foundation, exterior wall, and slab, it would be reasonable to expect that water could leak onto the carpet. But, my knowledge of concrete slab construction is very limited other than the fact that this is one of the reasons I don't like it.
Old 10-29-2009, 12:12 AM   #13
I think when I post the pictures you probably understand whether my foundation is slab or lumber.
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about buying lumber. Here I have two different types of lumber. This piece of lumber is treated and this piece of lumber is untreated. You know that it is treated because... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. However most of the building material that I will be using until I get the stud walls up and a exterior wall up and a roof over it could be expose to some weather without any... Read More »
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
Here’s some of the things that we’re going to be using today. Some of these things won’t be used only because instead of the blocks I’m going to demonstrate the straw bales being mounted to, you’re typically going to have an... Read More »
How to seal a shower pan liner against a concrete foundation wall? mgray87 Kitchen & Bath Remodeling 3 08-13-2009 01:08 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 03:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 11:11 PM
3 ft garden wall swarring Landscaping & Lawn Care 2 07-09-2007 12:32 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 11:20 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
