Decorative Stone Border - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 02:24 PM   #1
Rewards Points: 24
Decorative stone border
I purchased a truck load of decorative stone to use as a landscape border. I'd like to mortar the stones together but I'm unsure how to proceed. Does anyone have experience in this? Do I need to lay a concrete base under the stone? Is it ok to simply butter the side of each stone and mortar them together?
Thanks for any information.
John
Texas
john1529 is offline   Reply With Quote
Old 02-26-2009, 02:41 PM   #2
Remodeling Contractor
Dig a trench about 8" deep. Add 3-4" gravel. la about 2" cement. Then set the stones in place an allow them to set over night. Next day place mortar in the joints, tool after about 15 minutes. Clean joints and stone with a mason's brush.
Old 02-26-2009, 04:04 PM   #3
Rewards Points: 24
Bob,
Thanks for the reply. I thought sand was used. I'm glad I asked the question.
Is there a specific tool to use to force the mortar between the stones? It seems like it'll be tricky to get it in without something similar to an icing squeeze tube.
Old 02-26-2009, 05:07 PM   #4
You can do it this way. Buy what they call a grout bag. Very cheap. A pro would just use a triangular trowel to hold the mortar and a small jointing trowel to push it into the joints. Either way, be sure to pack them tight. Do not mix the cement or mortar too wet. More water, weaker concrete or joints.
Old 02-27-2009, 05:05 PM   #5
Rewards Points: 24
Thanks for the help.
Driveway border filled with "wire grass" Beth777 Landscaping & Lawn Care 10 07-21-2008 11:00 PM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 05:03 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
