Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-21-2012, 07:31 PM   #1
decorative grasses
We have planted several clumps of decorative grasses that reach about 48" when mature. They are easy to grow and look nice, but they continue to expand to where the girth of each outgrows the area intended, such as up to the fence and then overgrowing and hiding the decorative fence. How can we control the growth so we don't have to physically remove the edges each few years. The roots and crowns are very tough and it gets to be a big job.
lwendt is offline   Reply With Quote
Old 10-21-2012, 09:51 PM   #2
decorative grasses
You should have done some research before you planted it,a little to late now.
Canarywood1 is offline   Reply With Quote
Old 10-22-2012, 06:50 AM   #3
decorative grasses
Thank you for your kind and informative response.
Old 10-22-2012, 07:59 AM   #4
sdsester's Avatar
decorative grasses
I used to spec collars to go around grasses like bamboo that worked out great and kept them from invading into places I did not want them. You can use concrete or even better PVC drain pipe, cut deep enough to keep the grass roots from running.
Now, you may have to dig the plants out and replant them in the burried collars or sleeves. I suppose you might be able to trim your plants and slip them over the top.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
lwendt (10-22-2012)
Backsplash with uneven sides using decorative tiles mcride244 Kitchen & Bath Remodeling 0 07-25-2012 10:20 PM
decorative concave wood awning michigan girl Roofing 0 11-04-2011 09:38 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Tall Grasses... Jshakour Landscaping & Lawn Care 12 11-11-2008 12:56 AM
Do I need to dig away the grasses? KUIPORNG Landscaping & Lawn Care 9 06-08-2007 01:22 PM
