Decking Question! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 02:27 PM   #1
Decking question!
Hey guys im looking to start a small decking area in my garden and im hoping to have a curved edge to it and im just wondering what is the best way to clad the edge with?? Is it just some thin ply wood or is there more to it than that?? Would be grateful for any suggestions, thanks.
frank_cam is offline   Reply With Quote
Old 05-03-2012, 04:00 PM   #2
Rewards Points: 768
You can use composite trim board which is flexible or you can make relief cuts about every inch or on the back side of a 2x all the way around. The later method takes a lot of time and depending on the actually radius of the curve, it might not work.
cibula11 is offline   Reply With Quote
Old 05-03-2012, 06:24 PM   #3
Rewards Points: 12,818
COmposite fasha board would be the way to go, it comes 11 1/2" wide to cover up the whole rim joist and is only 3/8 thick so it will bend easy.
Use trim head screws to hold in place.
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
is the decking over foundation considered structure sn604s Building & Construction 4 01-21-2012 06:02 PM
Decking question ovahimba Building & Construction 3 04-03-2009 05:51 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
