Deck Piers Vs Poured Concrete Footings - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 11:05 AM   #1
Deck Piers vs Poured Concrete Footings
I am in the planning phase of a 12' by 22' free standing( not attached to the house) deck / patio. I live near Chicago. The deck will be used for a 10'sq ourdoor gazebo, table, and chairs. It will only stand about 6 inches off the ground. I plan to use Cedar or treated lumber, NOT that new composite stuff.
My question is, should I use the Deck Piers that require no digging, only flat land, or should I go with conventional concrete footings?
McSweny1103 is offline   Reply With Quote
Old 06-15-2010, 11:25 AM   #2
I too am debating the floating deck with piers or digging, mixing, pouring and setting. My biggest concern is a freak wind that could take floating deck away...
I do not relish the cement aspect and in the off chance we sell the property then it will give next owner options...
There is a thread that shows the steps for using piers and it looks pretty straight forward...I will prolly go with floating
Good luck!
Han'D' is offline   Reply With Quote
The Following User Says Thank You to Han'D' For This Useful Post:
McSweny1103 (06-15-2010)
Old 06-15-2010, 11:28 AM   #3
I was thinking about the possible "fly away" scenario as well, especially with the gazebo that i was planning on bolting to the deck itself.
To circumvent that I was going to drive some anchor rods into the ground during the building phase of the deck and bolt them to the 2x6 joists.
Old 06-15-2010, 08:23 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
concrete footings should be used and dug below frostline in your area. Probably 4 feet in chicago...check local codes. Proper footings should be used to keep the deck stable.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
Old 06-15-2010, 10:32 PM   #5
Appreciate the info. Looks like project cost will put this one on the back burner until next year.
Old 06-16-2010, 07:47 AM   #6
Chicago, IL
Michael Thomas's Avatar
One useful guide to building a safe and code compliant deck can be found at:
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
As a home inspector I encounter many, many problems with deck ledger design, flashings and attachment, and many of these are quite difficult to correct and can cause considerable water damage to the building to which the deck is attached.
For this reason I strongly prefer free standing decks which are not attached to the structure at all, there are a few potential problems, for example it may be difficult to find stable soil near the foundation, especially if the house is relatively new construction and the backfill around the foundation has not yet fully compacted. OTOH, you don't have to place your supports right against the foundation; you can easily cantilever a properly designed deck a few feet toward the house.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
jjgonfamily (06-22-2010)
Ideas for deck over concrete patio and beyond-pics- bdobs General DIY Discussions 11 10-22-2010 09:50 AM
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 10:40 PM
Building on piers & pressure treated posts, or just concrete piers? TinaRap Building & Construction 13 05-08-2010 04:00 PM
How to replace posts before concrete is poured rosco Building & Construction 31 05-07-2010 03:54 AM
Reinforce concrete piers? Neil_K Building & Construction 8 11-21-2004 07:53 PM
