Deck & Patio -> Grade Level? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 04:35 PM   #1
Hi folks,
I'm in the process of planning a deck and patio combination for my back yard, and wondering what to do in terms of the grade level for the two of them. The patio seems pretty straightforward - I will have 4 inches of gravel, 1.5 inches of sand and say 2 inch pavers so need to take 7.5 inches off the ground level.
What I'm wondering is what I should do underneath the deck. I was thinking I will add say 2" of gravel for drainage and weed control, but am not sure about the correct grade level. Should I take out 2" of dirt so that the gravel and patio will be level, just add 2" of gravel on top of existing grade under the deck or something else entirely?
jcoop_to is offline   Reply With Quote
Old 05-23-2013, 04:45 PM   #2
Rewards Points: 13,274
A wooden deck on grade never works out.
It needs air flow under it to dry out or it rots.
No 2X's are direct ground contact rated.
How would you get wide enough joist to support the deck in that small a space?
Old 05-23-2013, 05:03 PM   #3
Sorry, guess I should have been more clear - the deck is going to be about 3' above ground. I'm just thinking that I don't want plain old dirt underneath it and want the ground level transition from deck to patio to look nice.
Old 05-24-2013, 03:56 AM   #4
I have the same problem with my deck and was looking for some good idea on how to get my problem solve.Might as well post some picture here.
woodlandpatio is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Deck or paved patio if backdoor is 4 feet above ground? pood General DIY Discussions 12 04-04-2012 10:59 PM
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 01:55 PM
Water Dripping from Upper Deck onto Patio JamuJoe Building & Construction 6 11-22-2010 11:51 AM
patio vs deck inChampaign, IL Painting 0 11-13-2010 12:01 PM
