Cutting Wall Caps - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 10:30 PM   #1
Rewards Points: 790
Cutting Wall Caps
I've got a circular retaining wall that is about 12 feet in diameter and I'm getting ready to cut the caps to fit the curve. I've heard two suggestions.
1. Align the wall caps around the circle, measure the distance between the gaps in in the back of the cap, split the difference on each side and cut.
2. Lay a cap, skip the second position and lay the cap in the third position. Then lay another cap facing the opposite direction in between and make the cut.
Option one is what I was going with, but I didn't know if there is an easier way than having to trim 3/4" off of each side of every block??
cibula11 is offline   Reply With Quote
Cutting a door into basement wall klaffey Building & Construction 5 04-19-2011 03:37 PM
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
