Cutting Retainer Wall Caps To Fit A Curve - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 09:54 PM   #1
Cutting retainer wall caps to fit a curve
How do you figure out what angle/how to cut the cap pieces of a retaining wall to fit the curves in it?
georgeandkristy is offline   Reply With Quote
Old 10-10-2010, 09:45 AM   #2
GardenConcepts's Avatar
Rewards Points: 150
Layout the caps on top of the wall with the correct overhang front-to-back. See the gaps between each stone? You'll want to split the angle , so each cap gets cut at half the amount of the gap.For example, if you have a 45 degree angle, you would cut each cap at 22.5 degrees. If you were to cut just one end at 45 degrees, the depth of the cap would be different then the next adjoining piece. You should be able to use a straight edge and pencil, and just eyeball the correct angle- half of the gap between each cap. To get the best looking cuts, each cap (except the end caps) will be cut twice.
GardenConcepts is offline   Reply With Quote
Storage Shed Retainer Wall cmlatch Gardening Forum 4 04-03-2010 07:44 PM
Cutting a hole in concrete wall upinsmoke Building & Construction 4 03-07-2010 10:20 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Cutting a stud on load bearing wall timw Remodeling 5 01-12-2009 02:55 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
