Cutting Landscape Fabric - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-19-2012, 05:16 PM   #1
Cutting landscape fabric
I've never used landscape fabric before. What do you cut it with? Will normal scissors work or do I need something bigger. Thanks
phil74501 is offline   Reply With Quote
Old 04-19-2012, 05:30 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Scissors might work but a heavy utility knife might be better
Old 04-19-2012, 11:53 PM   #3
DIY Freshman
Scissors may work but my suggestion would be to use a utility knife similar to the one in the picture below. I use a hooked blade instead of a standard straight blade because I find it easier to use when kneeling on the ground custom fitting the fabric around obstacles or plants that are already established. Just as a note of advice, when putting down fabric and you need to cut a hole for something already established don't cut a circle. Cut an X and tuck the corners under. This will help minimize the amount of sunlight that gets past the fabric and therefore keep the weeds at bay. Good Luck!
elessar007 is offline   Reply With Quote
Old 04-20-2012, 12:03 AM   #4
Rewards Points: 13,300
I stopped using landscape fabric long ago. Ever seen a pro landscaper using it?
It will not stop the weeds from growing right through it.
Remove all the weeds and grass by the roots, spread Preen, apply 4" of mulch then add more Preen over it.
Don't belive me try just laying a piece on the lawn and weight it down and see what happens in a few weeks.
Old 04-20-2012, 02:24 AM   #5
Too Short? Cut it Again!
Upholstery fabric sheers will work but certainly cost you more than a good utility knife you will use for many other things.
Joe makes a good point. I think people sometimes expect more out of landscape fabric than what it can deliver. When practicing landscape design decades ago I seldom specified it except as a means of providing a boundary layer for decorative river rock or pebbles. And even then, it did not last nearly as long as one would like. Once it starts falling apart it is a pain to deal with.
I too would spend the money on a pre-emergent herbicide, labor to pull some weeds, and an appropriate layer of mulch.
Old 04-20-2012, 05:36 AM   #6
Ravenworks's Avatar
1) That is your choice
2) Yes I have many times
3)Without opening up the debate AGAIN the answer is false
OP you can you a utility knife or "Sharp" scissors,when you cut it you can leave the scissors open and use the throat to cut with.
Ravenworks is offline   Reply With Quote
Old 04-20-2012, 07:49 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 638
Ayuh,.... The stuff is basically plastic,....
I cut it with a plumber's torch,...
It cuts it quickly, 'n leaves a decent edge, without frayin'...
Old 04-20-2012, 10:21 AM   #8
Work Hard, Play Harder
Rewards Points: 212
I agree with the utility knife with the hooked blade. I used hooked blades on a roof last summer and I've never gone back.
I keep a regular box cutter around with normal blade and then I have a pocket knife version of a box cutter and I keep hooked blades in it. I plan to use that for my landscape fabric in the coming weekends.
It's also better than a scissors in that you can retract the blade and put it in your pocket while you work outside. I wouldn't want to have a scissors in my pocket while working.
coderguy is offline   Reply With Quote
Old 04-20-2012, 03:56 PM   #9
Here's what I have going. I moved into this house 2 years ago. The house sits on a slope. The builders had leveled off for the foundation, and then built a retaining wall behind the house. The distance between the house and the retaining wall varies from about 19 feet to about 3 feet. They filled in the gap with small gravel chips. I park behind the house and walk through that gravel to get inside. Everytime I walk through it my shoes pick up little bits of gravel and transport it into the house. So I've decided to make a walkway with paving stones. That should stop the gravel getting into the house.
The first 2 years here not much grass grew in that gravel. Last year we had a drought and there wasn't any grass. This year the grass is sprouting up like crazy. I sprayed it yesterday with Roundup. I discovered in the past that Roundup will kill the stuff, eventually, but grass will sprout up somewhere else. What I want to do is lay down the landscape fabric, build the walkway across it, then cover the fabric with rocks. The reason for the landscape fabric is to keep the grass and weeds from growing.
Old 04-20-2012, 03:56 PM   #10
Rewards Points: 1,574
I"m with Joecaption; wouldn't use the fabric again. Preen, weeding, and RoundUp are easier in the long run.
bob22 is offline   Reply With Quote
Old 04-21-2012, 09:28 AM   #11
Rewards Points: 768
Fabric is and should be used by everyone, including the pros. There is the 'cheap' stuff that is thin and will allow grass to grow through it. But you can buy thicker, more durable fabric that is really high quality. Preen will NOT keep the weeds out permanently and certainly not for very long periods of time. Not to mention the cost associated with applying that much weed preventer to an entire landscape.
In areas that I don't have plants growing, I have used black plastic, which is much cheaper than landscape fabric, but doesn't allow water to penetrate to get access to plants.
Bottom line...no matter what method you choose, you can never completely get rid of all weeds. Not unless you live in an area where there is NO wind and non of your neighbors have weeds of any kind.
cibula11 is offline   Reply With Quote
The Following User Says Thank You to cibula11 For This Useful Post:
Ravenworks (04-21-2012)
Old 04-21-2012, 11:52 AM   #12
Ravenworks's Avatar
I have been using fabric since Hector was a pup,I have never had a weed.
My new house had terrible weed problems ,put down the fabric and weed problem gone.
The key to a good job starts with quality materials and proper methods of installation.
Old 04-22-2012, 05:20 PM   #13
Raven,
What about the weeds that root above the fabric in the mulch?
Old 04-22-2012, 06:12 PM   #14
Ravenworks's Avatar
Originally Posted by bob22 View Post
Raven,
I haven't had any while using fabric except one time and it was my fault.
I did a complete redo for my mother one year and used cheap mulch.
Well that cheap mulch cost my another weeks worth of work and about a grand in materials because it was full of thistle and what ever I did I couldn't kill it.
I took all the mulch out and haven't had a problem since.
Old 04-23-2012, 07:46 AM   #15
Rewards Points: 768
Raven,
pull em when you see em
You'll never get rid of all weeds. Even with a product like Preen. If you don't want to ever see a weed.....then don't look.
Landscape fabric under gravel driveway? jpsmith Landscaping & Lawn Care 15 12-09-2012 10:24 PM
Retaining Wall Geogrid + landscape fabric? teamcampreder Landscaping & Lawn Care 5 03-26-2012 07:03 PM
Landscape Fabric rjordan393 Landscaping & Lawn Care 3 03-22-2011 07:17 PM
Alternatives to landscape fabric? ricksample Landscaping & Lawn Care 10 02-01-2011 04:18 PM
Cutting pressure treated landscape timbers; the cuts ? Sven Landscaping & Lawn Care 6 01-20-2008 08:35 AM
