Cutting Down A Mexican Fan Palm - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 08:20 PM   #1
Rewards Points: 37
Cutting down a mexican fan palm
Hi all
the previous owners of our house went nuts with palm trees. We have 30+ palm trees on our property... and our lot is not big at all!
so there are several mexican fan palms that i will be needing to cut down some day. they are small (5-8') tall but 10 years from now, they will cause major problems.
is it a hard diy? i'd imagine cutting down the branches and the trunks with chainsaw wouldnt be too hard.... how about taking out the stump? could i leave the stump? would it start growing back?
joshik is offline   Reply With Quote
Old 04-26-2013, 08:42 PM   #2
Too Short? Cut it Again!
It is not a good idea to leave stumps of anything. You just ask for bug and other problems.
Your palms are shallow rooted. If you can get to them and get a chain around them and hooked to a solid truck or tractor, I would pull them over when you can get a hold of them.
Then you can cut them up. But be prepared for your chainsaw to get gummed up since they are fairly fibrous.
You already know but make sure you have some heavy gloves handling them! Suckers can tear up your hands if you grab them the wrong way.
It is too bad somebody overplanted them. They are rather nice looking and low maintenance compared to other things.
Somebody else might want them and be willing to help you pull them out if you do not have access to a truck, tractor or whatever. They usually take to transplanting fairly well as I remember. Try a CL post?
Old 04-26-2013, 09:15 PM   #3
Rewards Points: 37
yeh i know... i feel bad cutting them out. i was thinking of selling them but i dont think they have much resale value.
i was thinking of posting it on CL... free if you help take it out. unfortunately, there is no room for a truck to pull the tree out.
if someone was to want to take it and replant it, would you just cut off all the branches and then pull the whole trunk and root system out at once?
Old 04-27-2013, 05:55 AM   #4
Obviously the more of the plant, save for extraneous branches that would be damaged anyhow, you can save the better its chances of snapping out of transplanting quickly.
So, if planning to rescue these I would dig around the base and root ball, and then pull them out as close to intact as possible. If you cannot get a truck it may just take a rope and some collective brute force. You risk pulling the wrong one out if you try to use a come-along or something hooked to another one.
Would a little bobcat fit? Careful not to tear up your yard in the process here though.
I guess the first thing is to see if anybody wants them.
Old 05-02-2013, 09:44 AM   #5
We took out an 8ft fan palm last month, I sawzalled the fans off then went out about a foot from the trunk and started digging for roots. They do have very shallow roots no deeper then 8 inches I'd say most cut with the shovel but there were groups of roots that were easier to get to with the sawzall. Once the roots were cut between my dad and I with shovels we lifted it out, ours went in the green waste can since they come up like weeds here.
Sami_3000 is offline   Reply With Quote
Tips for Cutting Baseboards and Door Trim hellothere123 Carpentry 25 10-20-2012 09:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 09:20 AM
