Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-19-2013, 10:39 PM   #1
Curb Appeal ideas?
Just bought this rental and want to spruce up the outside with minimum cost and also low maintenance, as tenants rarely take care of landscaping.
Any ideas for best color for awnings and some low maintenance landscaping?
I'm also looking for porch railing ideas....and some sort of barrier on each side of the driveway to the basement. It is currently a fall hazard that I need to remedy without a lot of cost or it looking tooo tacky.
Thanks!
Drhoda is offline   Reply With Quote
Old 01-19-2013, 10:43 PM   #2
Curb Appeal ideas?
One more side pic
Old 01-19-2013, 10:49 PM   #3
Curb Appeal ideas?
The longest lasting no maintaince railings would be to use anidized aluminum set in core drilled holes and set with epoxy.
A simple vinyl picket fence along the drive.
Make sure to set it high enough that a weed wacker will not have to hit it.
As far as landscaping I'd forget about it until you want to sell it.
I know my rentals all have trees and hedges and no one ever cut them or rakes the leaves. You'll be lucky if you find a good enough tenet to even mow the lawn.
One thing I can see that may be an issue is that garage door. Looks like a DIY built door.
Old 01-19-2013, 11:11 PM   #4
Curb Appeal ideas?
Yeah it is actually not even a garage. It is only 5 foot. Place to put a lawnmower and such. I may even lock it to keep the temants out as there is a shed out back as well.
I know what you mean about tenants taking care of the landscaping and yard. I was at least thinking about some hedges that don't require a lot of trimming
Old 01-19-2013, 11:17 PM   #5
Curb Appeal ideas?
I would get some gutters up on that side that needs a railing.
Right now you have water falling on the stoop, steps, driveway.
If you go back and add your location to your profile someone may suggest what type shrub to but in.
Old 01-20-2013, 04:26 PM   #6
Curb Appeal ideas?
Isn't the main reason for gutters to get water away from the house? I thought about installing some but the yard slopes quite dramatically so the water effectively drains toward the road.
Old 01-26-2013, 12:32 AM   #7
Curb Appeal ideas?
First off, I'd say loose the two shutters on the front. Awnings fazed out shutters, so they are purely decorational now. However, they just don't work when they don't appear operational at all... too short to cover windows and awnings in the way. For the awnings, I'd say to paint the classic, with every other slat painted black. The garage door kills the appearance too. For the landscaping, I'd say a few simple, low maintence evergreen shrubs, similar to this boxwood (However, it is currently sold out. Should be back in the spring.) Plant a few spaced infront of the porch on either side of the steps. Odd numbers like three on each side usually are the most appealing. http://parkseed.com/buxus-sempervire...alley/p/48606/
Also, freshen up the steps with a new coat of durable, oil-based paint.
mt999999 is offline   Reply With Quote
Old 01-26-2013, 04:23 PM   #8
Curb Appeal ideas?
Get rid of the siding on the doors so the surface is flat,paint it white and add black decorative carriage house hardware to the doors,ebay or Amazon has the hardware at a reasonable price.
Canarywood1 is offline   Reply With Quote
Old 01-26-2013, 10:07 PM   #9
Curb Appeal ideas?
I think it is this house which people have in mind when they talk about making abortion illegal.
cleveman is offline   Reply With Quote
Advice on improving curb appeal mozzles Remodeling 7 01-10-2013 08:37 AM
The Start Of Updating Our Curb Appeal Focker Project Showcase 12 10-25-2012 08:29 PM
curb appeal LFisher Remodeling 7 07-27-2012 04:35 PM
Exterior/ Curb appeal Blackwater Remodeling 5 04-17-2012 02:02 PM
Guide: Adding curb appeal! Grumpy Remodeling 1 12-31-2003 01:26 PM
