Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-01-2009, 12:08 PM   #1
cub cadet m48 zero turn stopes running
My cc has a kawasaki 19 hp motor #fh601v I am abel cut for about one hour or so then it just stops like it runs out of fuel. It will restart but right a way but will only run for a couple of min . Their is nothing in fuel filter, or fuel pump but fuel. both plugs look good . my guess is electrical but not sure what to try
emmit6875 is offline   Reply With Quote
Old 09-01-2009, 12:55 PM   #2
Kap
Mowing my life away.
Check fuel line to make sure it's not too close to engine or other heat source (vapor lock). How's the oil level?
Kap is offline   Reply With Quote
Old 09-02-2009, 10:20 AM   #3
fuel lines had not moved but do not seem be in a bind or have been to hot . oil is on full line was changed at start of season
Old 09-03-2009, 08:00 AM   #4
gravity always wins
Check the wiring to the safety interlocks. There are interlocks under the seat and on the deck to shut off the engine if you attempt to get out of the seat with the blades engaged. I had a wire on one of them rubbed through. It would short the ignition system and shut off the engine. Some electrical tape solved it quickly.
Maintenance 6 is online now   Reply With Quote
Old 09-04-2009, 06:54 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
post deleted
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 09-07-2009, 05:40 AM   #6
Familyman
do you have an automatic choke. my honda mower had the same symptoms. the spring that regulates the choke had slipped out of the retaining eye. It would start, as soon as it warmed up it would die, and would not start again until it cooled down. I found the spring on the retainer but not in the eye. 15min fix
matt700 is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
outside unit kicks on, fan won't turn. Roger Nuss HVAC 9 07-20-2008 06:59 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
