Crushed Stone At Gable Ends Of House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-16-2013, 06:08 PM   #1
Rewards Points: 165
crushed stone at gable ends of house
I am planning on adding crushed stone around the gable end of my house. The roof has basically no overhang on the end and water hits the ground and causes mud to splash up. What size stone should be used for this, and how to I go about getting the grading right? Also, where the rock meets the grass should I install some sort of edging? Thanks in advance!
chronojosh is online now   Reply With Quote
Old 10-16-2013, 08:07 PM   #2
Rewards Points: 12,868
Got some pictures.
If you raised the grade and grew grass there, there should be little splash back.
If you add stone you should also add a French drain or it may effect the foundation.
Old 10-17-2013, 10:35 AM   #3
Rewards Points: 165
Hope these help. The yard has a gentle slope from back to front (right to left in the pictures)
How to enclose soffit at gable ends? mklein49 Roofing/Siding 10 10-11-2013 02:56 PM
Housewrap on gable ends? paullo Building & Construction 12 07-14-2012 08:40 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 01:55 PM
Building A Stone House In An Semi-Earthquake Enviroment Silverbackman Building & Construction 12 03-28-2006 03:43 AM
