Creating A 'cap' For A Deck Railing - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 11:48 PM   #1
creating a 'cap' for a deck railing
I have a railing on my deck that I would like to top with tile, or something. The downfall is that I live in an apartment so nothing can damage anything.
I had the thought of using a board slightly wider then the railing, and to then tile on top of that, and just place it on the top of the railing. The railing is actually a short wall that is stucco, and has metal rails coming out of it. I would like to give the 'cap' a bit of an angle away from the interior of the deck, so that water that drips down on it will run out of the deck. Right now the water pools, or comes into the deck.
My difficulty is I am not even sure where to start, and I have NO tools to work with.
Railing is 7 inches wide and 92 inches long. Here is a picture of it.
http://smallspacegardening.info/?p=41
I would love so input on at least where to start. Maybe suggestions on what I can do.
Melissa
http://www.smallspacegardening.info
smallspacegarde is offline   Reply With Quote
Old 05-23-2013, 07:36 AM   #2
Rewards Points: 13,300
Pictures woul not come up.
I'd forget at tile. It's held in place with thin set and could not be removed later without damaging whatever it was attached to.
Old 05-23-2013, 11:26 AM   #3
kimberland30's Avatar
How would you attach the board to the top of the wall? You'll need to anchor it somehow.
kimberland30 is offline   Reply With Quote
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 06:45 PM
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 08:16 AM
Getting deck railing posts plumb S-L-O-W-L-Y (!) chrisv2 Building & Construction 5 09-04-2012 08:02 AM
Deck Railing and Green Walls thetalkingmule Building & Construction 0 06-03-2012 12:23 AM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
