Craftsman Or Troy-Bilt - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-03-2007, 11:43 AM   #1
Craftsman or Troy-Bilt
Looking to buy a gas pressure washer. Lowe's has Troy-Built and Sears has Craftsman with basically the same specs:
Briggs & Stratton 675 Series engine
Axial cam pump
2550 psi, 2.3 gpm
I will be using it to clean my deck, patio furniture, car, siding, etc. Probably adds up to 6-10 times per year for a few minutes each time. Once in a while I will hit the driveway and sidewalk. I guess I need a light to medium duty unit. I've killed two Husky electrics, so it's time to step up to gas, but I'm not spending huge money on a commercial grade machine. Any advice or opinions?
Chardo is offline   Reply With Quote
Old 05-03-2007, 12:46 PM   #2
Rewards Points: 1,088
How much are you looking to spend?
You can get a Karcher gas pressure washer with a Honda engine from Costco or BJ's for about $300 -$400. I bought mine for $300.
http://www.costco.com/Common/Search....v-_-Top_search.
handy man88 is offline   Reply With Quote
Old 05-03-2007, 01:17 PM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
The ONE thing I have always like about sears has been the craftsman power products. Everything my family has ever owned in the way of hedge trimmers, lawn mowers, etc has been great and has lasted. I didn't hesitate to buy a craftsman lawn tractor this passed year. I know that doesn't help a lot, Just my experience.
J187 is offline   Reply With Quote
Old 05-03-2007, 02:48 PM   #4
I want to stay under $300.
That Karcher model at Costco has 2600 psi and 2.3 gpm, almost identical specs as the Craftsman and Troybuilt. Karcher is $369, and the others are $279. Other than the Honda vs. B+S engine, why is the Karcher better?
Old 05-03-2007, 03:09 PM   #5
J187's Avatar
Rewards Points: 506
May want to read this, I don't think its the exact model youi are looking at, but may be an indication....
http://www.epinions.com/hmgd-Shop_To...splay_~reviews
Old 05-03-2007, 03:14 PM   #6
Premium is for Honda engine. If you stop by the costco, or BJ's, you might be able to pick one up like me for only $300. Costco has a very generous return policy. My tools with Honda engines start up easily every time.
Personally, I don't trust Sears Craftsman for heavy duty or medium duty work. Here's a sears brand with a honda engine though:
http://www.sears.com/sr/javasr/produ...cemldffidfno.0
Old 05-04-2007, 09:08 AM   #7
Rewards Points: 264
In my opinion, anything without a Briggs engine.
Jeekinz is offline   Reply With Quote
Old 05-04-2007, 10:20 AM   #8
The same specs as that Sears/Honda unit are also available in a Lowe's/Troybuilt machine. Same engine and pump. Am I better off with the Sears or Lowe's machine?
Why "anything but" Briggs? Isn't it the pump that usually fails on these things? Does engine brand make that big a difference?
Old 05-04-2007, 10:44 AM   #9
Given that both machines have identical pumps, the Honda wins hands down.
Old 05-04-2007, 12:12 PM   #10
Rewards Points: 264
The pump will fail if you do not winterize properly. I have never had a Briggs last longer than a year without repairing something on it. Techumseh is my power source of choice.
Old 05-04-2007, 11:28 PM   #11
Tecumseh gets some bad opinions here and there, but I've never had a problem with my Tecumseh snow king engine for my Ariens snow thrower.
Other good engines out there include Kawasaki and Kohler.
Old 05-07-2007, 12:42 PM   #12
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I would NEVER buy anything craftsman. Too much bad luck. Maybe a open ended wrench or screwdriver but thats it. Brigs is a fine engine as is honda and techumsa. Just maintain them and you will be fine. I would get the troybuilt if those were my choices, hands down.
Brik is offline   Reply With Quote
Craftsman miter saw woes Joebloggins` Tools 8 11-01-2011 10:13 PM
Is the 1/2" Craftsman Drill a goner? KUIPORNG Tools 1 02-26-2007 12:22 PM
Craftsman Table Saw Question TonyCooper Tools 2 12-01-2006 09:44 AM
Opinion on HD American Craftsman replacement windows Jims69 Remodeling 2 10-26-2006 04:02 PM
