Craftsman Tractor Not Running Right - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 05:26 PM   #1
Craftsman tractor not running right
I have a craftsman lawn tractor with a 19.5 hp Briggs twin cylinder which i inherited when I bought my house, the guy said he had it serviced yearly which is certainly a lie, I used it once last season and I have to keep it choked half way to keep a consistant RPM, if I pushed the choke 3/4 in a get a choppy idle that revs up and down every couple seconds. I took the carb off thinking maybe that was the problem, it was perfectly clean, nothing in the bowl. A guy at work was telling me I may have a clogged jet, I am not an engine guy so I have no clue where this would be in the carb, there is a capscrew on the side just below the bowl... is this it?
naehring2000 is offline   Reply With Quote
Old 03-09-2010, 11:08 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Ayuh,... In that case,.. Have the carb Rebuilt...
It's no doubt plugged up in 1 of the many tiny passages inside it...
Bondo is online now   Reply With Quote
Old 03-27-2010, 09:56 PM   #3
Replace the fuel filter. My Craftsman GT5000 requires I do it every year. Stick with the Sears brand filter.
StahlMaster is offline   Reply With Quote
Running Under ground wire Robbro137 Electrical 1 08-21-2009 05:11 PM
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 10:07 AM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 09:33 AM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 01:48 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
