Craftsman Gas Blower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 10:42 AM   #1
Question
Does anyone know where I can get some detailed instructions on how to wind the power cord for this blower. I have it disassembled and want to simply rewind the cord without having to take it to get repaired. No one has detailed instructions. HELP
gmmulgar is offline   Reply With Quote
Old 06-15-2010, 12:58 PM   #2
Do you know the direction of rotation?
Old 06-15-2010, 01:03 PM   #3
craftsman gas blower
I do not know as the rope was pulled from the assembly during start up. It seems to be simple but not sure how it all goes together. It has a screw that holds the rope following a thread through a hole and then winding it. I put it back together and the rope simply pulled out. Not sure if it was done right and there are no details from craftsman as they want you to take it to sears for repair. Probably could get a new one for the service. Any other ideas?
Old 06-15-2010, 02:03 PM   #4
The rope winds in the direction that opposes the coil spring that retracts the rope. If you don't feel this resisting force on the rope pulley in either direction the spring or its anchor may be broken. Wear eye protection.
Old 06-15-2010, 02:16 PM   #5
Gas Blower Rope
Thank you and I will try that for sure.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
