Originally Posted by bob22
Model #?
Model # is in the title of the post.
Does where you put the spring allow the auger to engage?
I assume if so, you can't stop the auger?
You didn't show a picture of the belt cover and the "a small metal piece with two holes in it fell out and I had no idea where it came from."
Those might help.
It would seem to me that the idler pulley is meant to either keep the belt tight so auger runs whenever engine runs or keep belt loose enough so that some other mechanism can be used to engage (make pulley move to tighten belt and engage auger) the auger. Is there some lever or something to engage/disengage auger?
This is a very simple snowblower. The auger is always spinning when the engine is on, so the pulley in question is just a tensioner, I think, w/ constant tension provided by the spring. There is no lever to engage / disengage any drive or auger.
I think I have the problem solved now, but thanks for your reply. I'll pick it up again if something more goes awry -- we're expecting up to 4" in the next couple of days, so I'll certainly be able to use it.
EDIT: I didn't realize that I hadn't done an explicit update on the washer/spring terminator part. I *did* successfully install that when putting the last cover bolts in and it does appear to work fine, it's a better location for the spring than what I'd fudged before and I'm sure it's how things were originally. Thanks to those who replied and read my post.
