Craftsman 27.0HP Tractor - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 10:15 AM   #1
Good Afternoon,
I have a Craftsman 27.0 riding tractor. Tractor is not starting, we charged battery and decide to purchase a new battery just in case. Install new battery and tractor still not turning over and there is gas in tractor. So when you turn key, all you hear is a click sound, nothing else. Can you and how do you test the ignition switch or faulty solenoid or starter? Any advise will be greatly appreciated... Thank You
Lisa in CT
gldn4rets is offline   Reply With Quote
Old 05-13-2011, 02:14 PM   #2
A Little Of Everything
Rewards Points: 1,364
Replace the starter solenoid. Done deal. It should look something like this...
It should be easy to locate, because the positive battery cable will be connected to it.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
gldn4rets (05-13-2011)
Old 05-13-2011, 04:24 PM   #3
Rewards Points: 256
yep id say cylinoid to .
oldrivers is offline   Reply With Quote
The Following User Says Thank You to oldrivers For This Useful Post:
Old 05-13-2011, 04:40 PM   #4
Thanks for the advise, will try that....Have a good weekend..
Old 05-13-2011, 06:31 PM   #5
Rewards Points: 148
I would head that way too, but, after checking that the cable ends are clean and tight at the battery, the solenoid, and the ground from the negative battery cable to the frame.
The Following User Says Thank You to DexterII For This Useful Post:
Craftsman miter saw woes Joebloggins` Tools 8 11-01-2011 09:13 PM
Similar to Craftsman, but built in 1900? TOTALN00B General DIY Discussions 3 02-18-2011 10:23 PM
Craftsman tractor not running right naehring2000 Landscaping & Lawn Care 2 03-27-2010 09:56 PM
Craftsman air compressor blowing breaker Frankenberry Electrical 38 10-10-2009 07:02 PM
Craftsman 19.2 problems..please help lairdness Tools 12 08-17-2009 09:14 AM
