Cracked Beam On Cedar Pergola - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 08:04 PM   #1
cracked beam on cedar pergola
Contractor just finished up today installing a cedar pergola and i noticed a crack on the beam. Should i live with it or circle back with the contractor to get fixed?
brianxmurray is offline   Reply With Quote
Old 06-06-2012, 08:57 PM   #2
Civil Engineer
Rewards Points: 4,944
This is not a structural issue, if anything it is an aesthetic issue. If your contract called for installation with no splits, you might have a case, else I would not worry about it.
Old 06-06-2012, 09:10 PM   #3
Thank you for the quick response. Contract called for rough sawn cedar.. so I'm good with it since it shouldn't pose a structural risk
Old 06-06-2012, 11:01 PM   #4
Too Short? Cut it Again!
If it bothers you something like Abatron epoxy filler, tinted to match the cedar or the color you stain it, will make it so you never notice it. Most would not anyhow.
Cedar vs. pressure-treated pine for pergola posts SteveinMD Building & Construction 15 07-23-2012 09:46 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
A Beam for a Pergola rv8tor Carpentry 18 10-30-2007 12:01 PM
Cracked Basement Beam lpcon Building & Construction 12 04-12-2007 07:47 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
