Crabgrass Preventer - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-28-2007, 08:51 AM   #1
Rewards Points: 790
Crabgrass Preventer
With our temperatures last week in the 80's, should I apply my crabgrass preventer a little earlier? We have 60's now but next week it should be back to low 50's. Everything is growing fast, I just don't want to put it on too early.
cibula11 is offline   Reply With Quote
Old 03-28-2007, 11:53 AM   #2
Rewards Points: 1,088
Rule of thumb is to put down the stuff when ground temperature hits 55-65. Right now is probably a good time. Worse case is to make another application in two weeks.
handy man88 is offline   Reply With Quote
Old 04-03-2007, 11:40 AM   #3
Crabgrass is no good.
TrexConsumer is offline   Reply With Quote
Old 04-03-2007, 12:57 PM   #4
Rewards Points: 790
Thanks for the enlightening repsonse. I applied the crabgrass preventer, and luckily the temps have dropped back to normal so I should be good for a few more weeks. I actually had to mow yesterday. Kind of depressing knowing I will now be mowing for another 5 months.
Old 04-03-2007, 01:25 PM   #5
Probably wasn't a good idea to mow, especially if you bagged it. If you bagged it, then all the fertilizer/preventer may have been sucked away. If not bagged, some of it could be tossed around, but not as bad as bagging your clippings.
Old 04-05-2007, 12:11 PM   #6
Rewards Points: 790
I did not bag it, and we had received an entire weekend of rain so there was no evidence of fertilizer on the lawn.
Old 04-16-2007, 08:51 AM   #7
Cibulla,
What did you apply?
I would use a combination fert/pre-crabgrass.
Something with a product called Dimension.
Dimension is a pre-emergent crabgrass control that offer post emergent control as well.
Find out what you used.
Always follow the directions.
More is never better and in fact can cause troubles for you.
Pilgrims Pride is offline   Reply With Quote
Old 04-16-2007, 02:07 PM   #8
Rewards Points: 790
I used a generic crabgrass preventer. The temps last week got really cold, so I don't see any crabgrass. I also think I might have an issue with fox tail, so I'm hoping the preventer will help that too.
I will probably be applying a weed and feed in the next few weeks.
Lawn overhaul jmontgom Landscaping & Lawn Care 6 03-22-2008 07:33 PM
Applying Crabgrass Halt gregt848 Landscaping & Lawn Care 1 05-02-2007 03:01 PM
