-   -   Correct Fence Install (http://www.diychatroom.com/f16/correct-fence-install-139250/)
mikeylikesit580 04-04-2012 07:39 PM
I need to put up a new fence on my property. I am debating on either buying some home cheapo fence section or building my own. What is the best way to install the 4x4 posts. I have heard different things. One was to mix quickcrete and put the fence post in that, then I hear that the concrete will eat the post and I should only pour it into the hole, and set the pole on top of that. I've also heard that I should not use any concrete at all.
And Ideas?
biggles 04-04-2012 10:18 PM
8' pressure treated 4 X 4.....3'-4' deep into the hole depending on the fencing going up might get away with straight dirt fill in pounded down as you fill
sublime2 04-04-2012 10:26 PM
Posts put in the ground without concrete will fail.
Dig the holes to required depth pour some gravel,put post in and fill hole with concrete set post in concrete but not all the way to gravel finish hole with concrete about 1 to 2 " below grade and cover with dirt.
Thunder Chicken 04-06-2012 07:39 PM
Whatever you do, don't set the bottom of the post (the end grain) into concrete. Set the post at the right level using gravel, then backfill from there, tamping as you go. You can put dry mix in as backfill *around* the post. Concrete holds moisture and can hasten rot, even in pressure treat and cedar. Most of the pro fencing installers in this area don't bother with concrete. If your post is deep enough (which might be tough to do with the cheapo box store fencing), properly packed soil will be more than adequate to hold it straight and firm.
biggles 04-07-2012 06:28 AM
might want to tar the post 3' that goes into the hole,let them cure in the sun and that will add years to them.i did post and rail 20yrs ago and they are starting to rot at the ground and a little wobbly
mac44 04-07-2012 04:11 PM
As a part of this thread, what is the recommended pneumatic nailer picket fastener? I'v been told 2" staple or 2" nails W/ rings?
Millertyme 04-07-2012 06:44 PM
a properly tamped post will hold just fine, but again, it needs to be done right. Dont put a ton of dirt in the hole and tamp it at the top. It should be tamped at 4-6" intervals with a steel tamping rod...not a 2x4.
As for nail, I think ring nails hold well and is what most fence manufacturers use to hold on their pickets
