Cool Off Misting Fans - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 02:17 PM   #1
Cool Off misting fans
We love to spend time outdoors as much as possible, mainly in our outdoor living room. Inevitably things here in Texas get too hot to do so July thru mid September. We've been considering misting fans such as you find on restaurant and bar patios. One brand we notice most often in our area is Cool Off.
Anyone have experience with this brand or commercial grade misting fans in general?
Thanks and keep cool!
gstuartw is offline   Reply With Quote
Old 07-21-2011, 08:34 AM   #2
Don't know about that brand, but stay on track with a commercial / pressurized mister. The misters that just use the pressure from your water supply do not produce a fine mist and just ends up getting everyone and every thing wet. I ended up moving my mister to the base of my deck to water plants.
sippinjoes is offline   Reply With Quote
Old 08-31-2011, 01:18 PM   #3
Instead of a fan, limited outcome how about a ridgid installed system? I have seen systems range from $500 to $5000 profesionally installed.
Mid to high pressure are the only ones that work, low pressure systems aka city water pressure just get you wet. I researched the mid-pressure systems (>160psi) and I can buy the tubing online for $200, all I need to find is a HP hi-pressure low volume pump. Seems easy to build.
Now if you want a system with everything you need just nail up these prices aren't too bad http://www.cloudmister.com/p-267-mid...ting-kits.aspx
Calivette2003 is offline   Reply With Quote
Roof fans sucking air through chimney? Badfish740 HVAC 8 10-08-2008 11:01 AM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 12:03 PM
Inline Duct Fans for cool room CamL HVAC 4 12-06-2007 01:04 PM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 09:02 AM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
