Converting Bog Into Pond? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 07:26 AM   #1
Converting bog into pond?
Hi there. i have about 3 acres of land, and there are a few areas where there is boggy soil (can walk over it, but it's wet and water rises to the surface when you walk on it). does this mean there is a stream close to the surface? and if i were to dig out that area (about 4x4 meters), would it be a little pond? the bog soil is ugly, especially when the kids accidentally step in it, and it would be great to turn it into a pond instead, simply by digging it out. is this possible and does anybody have experience doing this?
ligyron is offline   Reply With Quote
Old 09-03-2011, 07:40 AM   #2
DIY staff
Rewards Points: 7,174
That is a natural for creating a pond----the water table is right at the surface.
Do a little investigating before you start work----
Some areas of the country are funny about touching wet lands ---
Also --you used the term 'bog' ---which is a special ecosystem---I think you may have used the term wrong and are describing a marshy area.
Google 'Bog'---
If the area is far enough from any structure the pond could be blasted as opposed to digging.-Mike-
ligyron (09-03-2011)
Old 09-04-2011, 06:30 PM   #3
So i did some digging today. dug out about a 2 yard trench, 1 foot deep and 1 foot wide. i guess it's not as boggy as i thought it was. i was hoping to find water right away. the soil is wet/moist. dark on the top and grey/clay/tough towards the bottom. no signs of water. is it because it's late summer and everything is dried up? or i just have to keep digging around until i come across a spring? or is the water table most likely further down?
thanks.
Old 09-04-2011, 06:38 PM   #4
Civil Engineer
Rewards Points: 4,764
By definition the water table is the level that groundwater rises to inside a hollow pipe driven into the ground (a well). If you dig a hole and do not see standing water in the hole, then the groundwater table is lower. The only way to find out how much lower is to either drive a piezometer in, install a well, or excavate the hole deeper. Groundwater fluctuates seasonally, how much depends on the specific soil conditions, rainfall amounts, and topography where you live.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
ligyron (09-04-2011)
Old 09-04-2011, 06:54 PM   #5
DIY staff
The water table varies by season---Do some more digging and see when and if you hit water.
You may need to leave the pit open till spring and see that happens.
Old 09-04-2011, 07:59 PM   #6
Thanks for the tips, friends
Old 09-04-2011, 09:49 PM   #7
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
Make sure that the bog isn't the home of the last two 3-legged transvestite salamanders in existence, or the local DEP and EPA will be all over you. It may not matter whether it is your land or not in such a case. Be careful.
Thunder Chicken is offline   Reply With Quote
The Following User Says Thank You to Thunder Chicken For This Useful Post:
oh'mike (09-05-2011)
Old 09-05-2011, 07:22 AM   #8
DIY staff
I'm sure that Ligyron has looked for rare and endangered traveling salesmen in that wet patch and will build a little Hobbit House for them if they are there.
underground electric under pond jason7858 Electrical 35 01-10-2011 03:52 PM
Pond heater shorting out?? Master Brian Electrical 2 11-16-2010 02:40 PM
Painting a plastic pond full of live fish: help please! snowfall Painting 24 07-10-2010 10:14 PM
rjhrjt wannabe pond builder rjhrjt Landscaping & Lawn Care 7 01-08-2010 10:24 AM
Getting pond ready for winter? sandyman720 Landscaping & Lawn Care 1 10-25-2008 11:51 AM
