Condensate Pipe Discharge Location ? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 05:03 PM   #1
Condensate pipe discharge location ?
There is a condensate pipe running from the upstairs air handler down the side of my house and it stops about 48" above the ground. There is a constant drip from it and the ground underneath the pipe is a soupy mess. I know how to add to the pipe and re-route it, but I don't know what to do with the water that comes out or where to route it too. If I just re-route and don't do something with the water I'll end up with soup somewhere else and that obviously isn't ideal.
Any thoughts on how to deal with this issue? If I could reclaim the water (flower irrigation?) somehow that would be ideal but there isn't really room for a full on rain barrel (and not enough water) along the side.
cellophane is offline   Reply With Quote
Old 06-24-2010, 05:10 PM   #2
Chicago, IL
Michael Thomas's Avatar
Is it the primary or secondary drain? If it's the secondary, it's supposed to discharge at a location where occupants will notice condensate if the primary drain line plugs and water is diverted to the secondary drain.
________________________
I’m paid to be suspicious…
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 06-24-2010, 07:40 PM   #3
that i do not know. i'll have to call the installer and ask.
Old 06-24-2010, 08:15 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
check your gutters the primary may be in there
Tom Struble is offline   Reply With Quote
Old 06-29-2010, 09:06 AM   #5
I installed a patio in my back yard last year, and the condensate drain was located where it would drip on the patio. Before prepping the area to lay stones, I dug a 20' long trench and buried one of those flexible 4" corrugated black drain pipes (with holes and mesh sleeve). I positioned the mouth of the pipe directly beneath the condensate output, and installed a grate to keep stuff out.
Haven't had any issues with it filling up, or seeing any evidence of it soaking into the soil above (such as a nice green strip of watered grass).
sethmorgan is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
