Concrete Pavers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 12:28 PM   #1
Concrete pavers
I was able to get some free concrete pavers and I want to make a little path in an area of our yard. This will not get a lot of use and I want to install at a low cost. I was going to install a barrier then some sand to set the pavers then cover area with tan bark. Does this sound resonable. We just spent a ton of $$$ landscaping so I dont want to spend much and honestly these we rarely get used, just a path to a nitch in side yard.
mrwoodty is offline   Reply With Quote
Old 06-11-2013, 12:55 PM   #2
Bill Kearney
Rewards Points: 1,174
You mean niche? Or a grotto? Got a Virgin Mary statuette in there too? I'm kidding, of course.
Don't know that I'd use bark mulch. You'd essentially just be prepping a weed garden once that blows away leaving soil in the gaps. Like in that picture already. I'd prefer larger gaps and actual grass growing between. Then you an just mow over it. But if it's too narrow the grass won't have enough room to get a solid root mat under it, and weeds will get through.
Update your profile with your location! There are probably any number of ground cover plants that might work, but without knowing where you're located it's impossible to suggest any.
wkearney99 is offline   Reply With Quote
Old 06-12-2013, 02:54 PM   #3
LOL, thanks WK. Yes I might just consider letting the grass or ground cover grow. Thanks
install concrete pavers over cement deck hmpjrs Concrete, Stone & Masonry 1 05-22-2012 07:21 PM
Pavers over concrete & grass? katkins0027 Landscaping & Lawn Care 2 05-18-2012 09:37 PM
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
concrete under pavers around pool deck , pavers go to edge of pool doggie44 Landscaping & Lawn Care 0 02-27-2011 10:40 AM
Concrete or Pavers ? mikesenior Landscaping & Lawn Care 4 05-02-2010 03:19 PM
