Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-28-2011, 09:36 PM   #1
retired guy
concrete paver problem
I have 16x16 concrete pavers for my patio. Each spring the joints and surface are filled with a mossy green substance. I pressure wash and use a chloirne solution, but this problem reoccurs each year. I installed the pavers on masonry sand (I realize my mistake), so the pavers are almost always damp. I was told to pressure wash and wait until they are as dry as they will get, and use a concrete sealer to help abate the moss. I do get plentiful sunshine for several hours so the pavers do dry during the good weather. I live in NC. Any thoughts on this?
igneous is offline   Reply With Quote
Old 03-28-2011, 09:40 PM   #2
Tileguy
Bud Cline's Avatar
So your patio is on the north side of your house?
Old 03-29-2011, 09:20 AM   #3
retired guy
Yes... N x NE. The moss problem is definitely a winter issue. Very little sun and damp. Right now, it is drying as well as it is going to. The sand was free so I used it. I laid the pavers like blue stone (I'm from PA) rather than the proper method, so I have no one to blame. Will the sealer idea work, or will I end up with a bigger problem trapping moisture in the paver?
Old 03-29-2011, 05:56 PM   #4
Tileguy
Bud Cline's Avatar
I don't see how.
Chlorine is only a short term answer. It dilutes quickly and everything reverts back to nature. Why wouldn't you treat the area with a commercial vegetation killer of some kind? Some of those chemicals may give you a couple of years but eventually they-too will dissipate.
Concrete paver manufacturers around Los Angeles CA? gante Landscaping & Lawn Care 2 03-27-2011 11:43 PM
concrete paver base mande78717 General Discussion 8 06-14-2009 12:38 PM
Problem - Concrete Porch Slope johnjsa Building & Construction 1 05-21-2009 12:03 PM
Any problem with concrete poured over copper pipe? Mikej-22 Building & Construction 5 03-18-2008 08:43 AM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 10:31 PM
