Concrete Patio...what Type Of Mix: 4 Sack, 5 Sack, 6 Sack - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 05:57 AM   #1
Rewards Points: 2,516
Concrete Patio...what type of mix: 4 sack, 5 sack, 6 sack
Planning on a 27' x 21 concrete patio slab for the backyard. Am taking estimates from local contractors.
I know that 6 sack has more "compressive strength" than 4 sack mix.
One of the contractors mentioned 4-sack. I know 4-sack is less expensive than 6 or 6.5 sack mix and I have no problem paying the little extra for the higher sack mix if in the long run the higher sack mix will stand up better to the elements???
BUT is there a reason NOT to use a 6 or even 6.5 sack mix for a concrete patio slab? I live in Ohio where winters get cold with lots of snow.
Thanks.
hammerlane is offline   Reply With Quote
Old 04-18-2012, 11:55 AM   #2
Rewards Points: 150
I live in Canada and I've never heard concrete referenced this way. But some things to make sure you have is:
Air entrainment (6% +or- 2%)
Max. water to cement ratio (0.50)
Minimum srength 28Mpa (4200psi)
No reason not to use higher compressive strength mixes besides cost.
Durability comes from the air entrainment, quality of concrete (aggregates, cements, admixtures) and the finishing.
psilva8 is offline   Reply With Quote
The Following User Says Thank You to psilva8 For This Useful Post:
concretemasonry (04-18-2012)
concrete patio kline78 Building & Construction 3 08-07-2011 10:36 PM
Concrete patio control joint marriedmanw Building & Construction 1 07-29-2011 06:23 PM
Concrete Patio Remodel brm6685 Landscaping & Lawn Care 4 10-27-2010 07:51 AM
What is a 'concrete sill' for a sliding patio door? mikedavid00 Building & Construction 13 03-16-2010 10:17 AM
Ideas for deck over concrete patio and beyond-pics- bdobs Building & Construction 6 05-10-2009 08:58 PM
