Concrete Patio Remodel
If the concrete is cracked, it should probably be removed- start fresh. On the hand, if you are committed to leaving the concrete in place then you could seal any cracks and install your patio on top. Keep in mind the height increase, especially if you have a door leading out onto the patio. Make sure the slab has enough pitch away from the house.
You can use a soldier course of pavers mortared or glued around the perimeter and the field set on a sand layer. Pavers come in different thicknesses- you could use a thicker paver for the border, and a thinner paver plus sand for the field.
Chris
