Concrete Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 02:35 PM   #1
Question
Concrete driveway
We have a driveway that is chipping and it is only 4 years old. It started to chip in the second year slightly. Other than this it is in good shape but I am worried it may get worst over time as it seems to be doing just that!
Any suggestions and has anyone re-surfaced a concrete driveway? Did it work and how does it look?
Thank you.
ermickie is offline   Reply With Quote
Old 04-18-2009, 03:47 PM   #2
Civil Engineer
Rewards Points: 4,520
Post a few pictures. The word chipping is not very descriptive.
Old 04-20-2009, 08:51 PM   #3
I belive you mean spalding when you say chipping. Spalding is a failure in the surface that is caused when too much water is addin the finishing process. It looks like pitting.
The problem with trying to resuface a spalding driveway is that the surface will continue to pit, even after patching and resurfacing. The only real cure is to remove and replace the drive using a reputable contractor.
sleep is offline   Reply With Quote
Old 04-20-2009, 08:52 PM   #4
Where are you located?
Snow, ice area - rock salt used?
Old 04-20-2009, 09:20 PM   #5
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 812
Just my 2 cents. Correct term is spalling, or spaulling, depending on where you hail from.
We see it in concrete that's been attacked by salt, in concrete outside subject to freezing temperatures, and we've also seen it from really bad pours (hot mixes), and from overworking the finish. We're the ones that get called in for repairs. We use epoxy mixes, and sometimes plain old cement repair patch compounds. Our work holds up to chemical plant traffic really well, but the products are very expensive. If it were my driveway, I'd try to repair a section with the repair patch compounds you can get at the depot. If that didn't hold up, I'd go the epoxy route. But that is quite expensive, and could end up costing more than the original pour. However they do hold up really well.
Aggie67 is online now   Reply With Quote
Old 04-23-2009, 08:13 AM   #6
Thank you for everyone's input and I will let the driveway continue to "spald". Just will it get worse or does it stop?
Old 04-23-2009, 02:19 PM   #7
Aggie67's Avatar
Rewards Points: 812
If it was a bad mix, it's all bad. If it was too much water sprayed on after the pour, it should be surface. If it's road salt, the more road salt that goes on the worse it will get.
You can try repairing and sealing what you have left. If you have a mason supply store in your area, take a picture of the damage and see what sealants and repair compounds they have. We've got a great one here in NJ, AH Harris, and they're a chain. That's the type of place you want to buy these products from.
Old 04-10-2010, 08:05 AM   #8
Well it is spring now and the driveway has more pitting and it looks awful. I have had two concrete companies look at it and one knew the day it was poured because he was working in the area on another driveway. This I recall as well. Anyway he says it was too hot to pour that day and that is the reason it is pitting. He did not pour his driveway and it looks beautiful! He states he knew we would have problems because of this!
So now I am looking at the expense of another driveway!
concrete driveway sinking phospher Building & Construction 13 04-06-2009 08:27 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 01:11 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
Concrete Driveway help - Hey Teetor modelav8r Landscaping & Lawn Care 1 02-25-2008 10:33 PM
