Colourbond Installation - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-13-2014, 10:22 AM   #1
Colourbond installation
Hi, I'm installing a colourbond fence and will be core drilling into a limestone retaining wall. My neighbour wants to build a brick wall on part of this limestone aswell. My question if anyone can help is:
-what's the minimum distance from the edge I can drill so both will fit but still be strong enough to last over time?
The wall is 190mm, the core is 130mm and the limestone block is 330mm wide. My calculations leave me drilling around 25mm from the edge, do you think this is enough???
Thanks in advance.
Buildbuildbuild is offline   Reply With Quote
Old 03-13-2014, 10:31 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Thanks in advance.
Ayuh,.... 'bout an Inch,..??
How big is the fastener,..??
How much load on the fastener,..??
Old 03-13-2014, 06:39 PM   #3
Not sure what you mean by fastener, these are just bought fencing kits that get slapped together. Poles concreted into the cores.
Old 03-14-2014, 08:58 AM   #4
Bondo's Avatar
Ayuh,.... Whatever yer puttin' into the hole ya wanta drill,....
How Big is whatever's goin' into the hole,..??
How much load is on whatever's goin' into the hole yer drillin',..??
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
