Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-10-2010, 10:55 PM   #1
Colloidal Clay
A customer of mine wants me to add colloidal clay around her foundation.
A local architect recommended it for drainage, then add dirt and top it off with sod.
Has anyone use this clay and what other terms are used to identify it and place and order?
No landscapers seem to know what I'm looking for.
Thanks, I'm getting desperate.....
RemodelMan is offline   Reply With Quote
Old 08-11-2010, 09:33 AM   #2
DIY Hack
Mr Chips's Avatar
Colloidal Clay
i think what you are looking for is commonly reffered to as "select fill". It's fill dirt with a percentage of clay and is very compactable, often used around foundations
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-16-2010, 08:36 PM   #3
Don't know it all, yet!
Colloidal Clay
You can't ask the architect?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-20-2010, 04:57 PM   #4
Colloidal Clay
my first noob question: where can you buy this stuff in small amounts at a time?
federer is offline   Reply With Quote
Old 08-20-2010, 06:45 PM   #5
DIY Hack
Mr Chips's Avatar
Colloidal Clay
You would buy it at a place that sells fill. Not sure what you mean by small amounts, but I imagine most of those places would sell you a bucketful if you are willing to pay cash!!
Old 08-20-2010, 08:25 PM   #6
Colloidal Clay
thanks for the reply. i need to try google a fill place then. thanks. i was thinking a couple 50lb bags to do one side of the house.
Old 09-16-2010, 01:41 AM   #7
Colloidal Clay
coming back to this-can you just dump the clay select fill on top of existing soil?
Old 09-16-2010, 07:12 AM   #8
DIY Hack
Mr Chips's Avatar
Colloidal Clay
yes, just make sure you backslope so water drains away from foundation
Old 09-16-2010, 08:07 AM   #9
steveel's Avatar
Colloidal Clay
It depends. The lowest the wood of your wall can come to the soil is.... well, I forget. Is it 6" or 8"? More is better, anyway. If you're already at that level, I wouldn't just add more without a professionals (architect/engineer) approval, and checking with your building dept.
steveel is offline   Reply With Quote
Old 09-16-2010, 08:36 AM   #10
Civil Engineer
Colloidal Clay
A colloid is a suspension. You can look up the exact definition of a colloid on Wikipedia. Clay is a family of minerals, consisting of several hundred different types. A colloidal clay is a clay which remains in suspension when agitated in water. This means that the clay is in the form of very fine particles which do not settle out of the water column.
A typical colloidal clay is bentonite, so named because it was originally mined in Benton Wyoming. It is essentially impervious, hence is used in waterproofing panels. It also holds water very well, but does not release it easily. Bentonite is used in kitty litter, well drilling fluid, waterproofing membranes, landfill covers, and many other applications, and can be purchased by the 50 lb bag at specialty stores that cater to drillers, or you can buy clay based kitty litter and take your chances on what you get.
Now as to why anyone would want to add such a product around their house, I have no idea. If added in sufficient quantity, it will make the soil effectively impervious, so water will run off rather than percolating downward. So far as I know, it will not improve the soil characteristics for growing plants. I have never seen it used for the purpose you suggest, but if the customer is convinced that they want it, well at least now you know what it is and where to get it.
Old 09-18-2010, 02:31 AM   #11
Question
Colloidal Clay
thats for the info. the purpose is for regrading-draining water away from the foundation. you dont think this collodial clay is a suitable material to accomplish this? not sure what you are getting at exactly. sorry i am slow and this is all new to me
colloidal clay in well water BobMac Plumbing 43 01-14-2013 09:11 PM
clay cap around foundation? patrickosu Building & Construction 5 08-21-2010 05:55 AM
Clay Soil Vs. Grass mahjohn Landscaping & Lawn Care 6 08-20-2010 08:43 PM
Removing clay stains from asphalt ljcox General Discussion 6 05-15-2009 09:54 PM
Improving Drainage in Clay Soil BigJimmy Landscaping & Lawn Care 1 03-23-2007 01:03 PM
