Closing Gaps In Fence To Prevent Dog Fighting - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 01:21 PM   #1
Thadius856's Avatar
Rewards Points: 504
Closing Gaps in Fence to Prevent Dog Fighting
My Beagle gets alone fine with the dogs on either side of our house and other dogs that friends bring over, but the Chihuahua on the other side of the rear fence gets him riled up every time. The other dog always barks first several times, then runs up and down the fence, and then finally my dog has to reciprocate, at which point I have to bring him back inside.
I want to close the 1/4" vertical gaps so they can't see each other running the fence line, hopefully preventing the problem. It's a 60' section of cedar pickets with the posts on the neighbor's side. At 7' tall and sitting on a concrete footing, I'm not worried about either one going under or over. I don't think I need anything taller than 2' to block their vision.
I've considered attaching plywood, OSB, underlayment, paneling, mesh screens, roofing felt, etc. Nothing seems to look right when I picture it. We get approximately 30 days of rain a year, lows in the 40's in the winter, highs in the high 90's in the summers, plenty of sun and low humidity.
What's a reasonably priced material that wouldn't be a huge eyesore?
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 11-08-2012, 01:56 PM   #2
Rewards Points: 13,254
Got a picture?
None of the materails you suggest would be sutable.
Simple stips of 1 X 4 cedar over the gaps would work.
Old 11-08-2012, 02:32 PM   #3
Thadius856's Avatar
Rewards Points: 504
Certainly. Sorry for the delay. Company just came over.
Old 11-08-2012, 02:53 PM   #4
Too Short? Cut it Again!
Originally Posted by joecaption View Post
Got a picture?
Jeeze Louise Joe, do you need pictures of the dogs or just the fence to offer that nothing is going to keep them from knowing each other is out and about?
They will hear each other scratching around and trying to sniff each other out.
The only hope is to teach the Beagle to bark in what was my second language at one time: California Contractor Spanish. This must include suggestions of knowing what the Chihuahua's sister and mother do for a living in cantinas!
Chihuahuas are a funny breed. They are fearless and noisy. Not much to do to silence them.
Old 11-08-2012, 03:50 PM   #5
Thadius856's Avatar
Rewards Points: 504
I see you've been touched by His noodley appendage.
Perhaps it's the case that they'll still bark at each other. However, it seems that he only barks when he can see the Chihuahua running the fence line back and forth. I put up a scrap piece of plywood (2'ishx8') along the fence line a few days ago, and he definitely does not bark when it's between the two of them. Perhaps he'd still bark if the whole fence was lined with it, though.
My only other options at this point are to dig in a chain link kennel a few feet away from the fence or to build a second fence. I can't keep the dogs in their crates all day every day while we're at work forever.
Old 11-08-2012, 06:19 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
my jack does the same with the neighbors jack ..... they chase each other up and down a 100' section of fence that separates us. actually at first I thought it was a territorial issue, after two years I've come to realize they're just letting off some energy
you need some gap for expansion of the fencing when it gets wets. what about a small hedge or some plantings?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-08-2012, 06:48 PM   #7
Yes and I know that dinosaurs and man existed at the same time. And in fact early man built solid fences with no gaps to keep neighboring dinos, of differing sizes, from barking at each other. Of course I also believe that the World needs more pirates if it has any chance of reversing global warming.
Old 11-08-2012, 07:49 PM   #8
My dog and the neighbours chase each other up and down the fence line too. When they can finally get at each other they just play. Beagles aren't aggresive anyway. And just think of all the energy he's burning. Less dog walking for you
Steve is correct though. They will always know when each other is there, whether or not they can see or not. And if allowed to escalate the barking will start eventually. Your best bet is to train him not to.
My protective Shepherd wants to bark at every noise and movement. A squirt bottle with water and just a touch of vinegar ( they hate the smell) in his face usually does the trick. Just seeing me holding the bottle will do it now
I suggest a blast with the garden hose or a bucket with a firm "no barking" wil teach him to behave
creeper is offline   Reply With Quote
Old 11-09-2012, 08:54 AM   #9
A Little Of Everything
Rewards Points: 1,364
Get a sheet of 1/4" moisture-resistant underlayment (about $10). Cut it into 4 - 12" wide strips. Spray the heck out of it with water sealer. Tack it onto your fence.
If "vision" is what makes your dog go nuts with the neighbor's Chihuahua, that should help.
This will probably last about 2 years. It won't be an ideal, or permanent, solution. But it'll be cheap, and might just do the trick.
DrHicks is offline   Reply With Quote
Old 11-09-2012, 10:49 AM   #10
Thadius856's Avatar
Rewards Points: 504
Ironic.
I order customized plates "WWRJD" a while back; 8-10 week wait sucks, still waiting.
Old 11-09-2012, 11:46 AM   #11
Rewards Points: 48
I question the liklihood of it being effective as well, but since you think it may work, and being a beagle and a chihuahua, I would run cedar slats over the gaps, from the bottom of the fence to just above the height of the center stinger. I would rip them something like 3/4" - 1" wide, predrill them for nails, and put a single nail in each slat into the bottom and center stringer, center in the slats, so that the nail passed through the gaps of the existing slats. That way, if they didn't work, or if you otherwise ever wanted them removed, they could be popped right off, with no visible sign that they had been there.
Old 11-09-2012, 12:01 PM   #12
Rewards Points: 678
It sure disappoints me all of you intelligent people have forgotten the value of DUCT tape for a temporary visual test. If it works move on to something bigger and better if you prefer.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
creeper (11-09-2012), user1007 (11-10-2012)
Old 01-04-2013, 12:56 AM   #13
Thadius856's Avatar
Rewards Points: 504
Well. I did nothing, since most responders said it wouldn't work.
We've worked on "leave it" a hundred times and it works brilliantly while I'm outside with him. The second he's alone out there, he starts the fence running and barking. I'll run out and give the command, he'll respond, and then wait until I leave again. When I get fed up, I tell him to "come" while touching my finger to the door, and he comes over all depressed like he knows he's in trouble. Every time. He gets it, it just doesn't stick for more than a few minutes.
Ditched the idea for a dog house and kennel. They're indoor dogs now.
Old 01-30-2013, 11:56 PM   #14
I once had the same problem what i did was that i bought a thick wood fence so that dogs could not damage it and avoid the dog fights..
paulsmith544 is offline   Reply With Quote
expanding foam for gaps in masonry foundation LMHmedchem Concrete, Stone & Masonry 6 08-22-2012 10:36 PM
How can I prevent silverfish in the expansion gaps of laminate flooring Cool HOME Flooring 4 07-23-2011 06:13 PM
moisture barrier, do I need roofing felt as added protection to prevent gaps for expandtion? I'm floating it. saundra Flooring 0 05-10-2011 12:36 AM
Clarification regarding fence posts flatcoat Landscaping & Lawn Care 2 05-16-2010 05:26 PM
New fence fade prevention Dr. Awsome Carpentry 5 10-07-2009 09:33 AM
