Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-18-2013, 04:32 PM   #1
Close bottom gap on vinyl fencing
What's the best way to close the gap from the ground to the bottom of a vinyl fence? I replaced wood fence with vinyl with the idea of sharing my neighbor's vinyl fence on one side of my house. After I put the other 3 sides up and went to pull down the existing wood fence that ran along my neighbor's vinyl I noticed huge gaps. I guess they leveled the top instead of adjusting from bottom up. Anyway, I have dogs that will not hesitate to run right under the gaps. In some places, the gaps probably measure almost a foot from ground to bottom of fence. Any suggestions are GREATLY appreciated.
Thanks!
Tminikel is offline   Reply With Quote
Old 02-19-2013, 08:43 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Talk to yer neighbor,.... It's His fence, not yer's to modify...
Bondo is online now   Reply With Quote
Old 02-19-2013, 09:05 AM   #3
Got a picture?
Old 02-19-2013, 11:26 AM   #4
Larryh86GT's Avatar
My neighbor has 2 dogs and his fence has gaps in the bottom also. He used chicken wire (poultry mesh netting) along the bottom as a quick fix. It's not pretty but it does keep his dogs in.
Larryh86GT is offline   Reply With Quote
Old 02-19-2013, 12:10 PM   #5
Newbie Bill
1 foot gaps?????
Something sounds screwed up. Post photos.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-20-2013, 09:02 AM   #6
Hi there - I came to this site looking for a solution to the same problem! I have a similar fence all around my back yard. Right now my husband has piled up logs, lumber, bbq grills, etc all around which makes it look like a junk yard! I have two cockapoo puppies who will actually push their way underneath the fence. They are still finding spots to escape.. My old neighbour who had the problem years ago with his little dog, used tent spikes which did the trick but if you have more than a few feet to cover, this could get expensive. I thought of the chicken wire method but really would like a permanent solution that won't look so awful. I'm with you on this one and hope someone can make a suggestion!
dee4156 is offline   Reply With Quote
Old 02-20-2013, 10:01 AM   #7
dee4146 you need to go back and post your own question not piggy back someone elses.
Old 02-20-2013, 11:11 AM   #8
Why, if it's the same question..
Old 02-20-2013, 11:25 AM   #9
Newbie Bill
OK, here is my suggestion even though I have to wonder why a fence is built with such huge gaps unless the terrrain is hilly.
Go to your local lumber yard and obtain some lattice. It comes in pressure treated, Cedar, and composite. Determine what would work the best for you. The woods can be stained to match the fence. Here is a page of them with various designs etc.
http://www.homedepot.com/Lumber-Comp...searchNav=true
Here on page 2 is lattice that is 2 feet by 8 feet long.
http://www.homedepot.com/Lumber-Comp...e#/?Nao=24&c=1
Then you can cut what you need to fill the gaps. You can even bury the lower portions of the lattice in the ground. Even though the pressure treated and cedar are resistant to rot, they both will eventually deteriorate. But it should out last your dogs.
Bill
Old 02-20-2013, 11:48 AM   #10
Moderator
kwikfishron's Avatar
Maybe a raised flower/veggie bed. Hard to say without seeing it, lots of ways to plug a hole. It really comes down to budget and what you want to look at every day.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 02-22-2013, 11:20 PM   #11
I had same problem but fence was on my side I have 2 chihuahuas I used vinyl cause it will last. I cut lengths long enough to go between sections (should be 8ftish) that were wide enough to cover gaps and some in ground, then staked with treated lumber ( but like I said it was on my side so I don't know if you will want that on your side since in sure your neighbor won't want it on his.). U could always (neighbor willing) use either vinyl azek or similar material of even treated lumber and screw it to posts to block bottom. Or there's always put up another fence on your side
kaschmid3 is offline   Reply With Quote
Vinyl repair patch ponch37300 Flooring 0 10-02-2012 09:52 AM
vinyl squares over vinyl? brewer362 Flooring 2 03-04-2012 12:24 AM
Buying Vinyl Fencing jte1130 General Discussion 1 09-27-2009 08:14 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
