Cleaning Sand From Lawn Sprinkler Nozzles - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 05:04 PM   #1
Cleaning sand from lawn sprinkler nozzles
I bought an old utility pump from a retiring landscaper last year, and have been using it to pump water from the river behind my house to water my back yard/field (this is part of the continuing recovery from Hurricane Irene, which filled my field with sand piles, some 8-feet high).
In any case, we've had rains recently, and all of my sprinklers stopped working. After checking the pump, which is blasting water (it's a 3.5 HP unit), we finally figured out that there is sand and grit in the water lines, which clogged up the sprinklers. Before the rains, the pump was feeding all of the 10 sprinklers I have connected to the pump without a hitch.
I'm using $15 rotary stake sprinklers, which water about a 50' to 80' feet diameter each. Links to them are below:
http://www.amazon.com/Dramm-15064-Co.../dp/B001P80H5E
https://www.google.com/shopping/prod...=0CGkQ8wIwAzgK
I'm going to drain the 2" dia. truck lines that come from the pump, as well as the hoses and other connection pieces - that part is easy.
I'm also going to put more filtration on the input hose that comes from the river.
My question is, how do I best get the sand and grit out of the sprinklers?
I can't change to clean well water, by the way. My well pump can't provide enough water to water my field.
Arnold Ziffel is offline   Reply With Quote
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 08:33 PM
Lawn Sprinkler zone always on jburchill Landscaping & Lawn Care 6 08-15-2012 10:21 AM
Hunter MP rotator sprinkler nozzles MeatHead Landscaping & Lawn Care 2 09-20-2010 09:10 AM
Planning my lawn sprinkler system secutanudu Plumbing 43 08-21-2010 10:57 AM
Any lawn sprinkler experts? Reddhead Landscaping & Lawn Care 2 07-24-2010 12:20 PM
